Waterneck and Thermostat -Edelbrock 7577 Magnum Air Gap
#151586
11/16/08 12:52 PM
11/16/08 12:52 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
Which thermostat and housing do I need to use with the Edelbrock 7577 air gap manifold for magnum heads?
There seems to be three different types of waternecks: Early (up to '78 style), which is what I have '78-'91 Pre-Magnum offset steel type '92+ Magnum Tall type.
Since I'm using this in a Duster i'd like to avoid the tall type if I can since I think its ugly and it would likely make my radiator hose interfere with my air cleaner.
Thanks for any help.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Waterneck and Thermostat -Edelbrock 7577 Magnum Air Gap
[Re: goldduster318]
#151587
11/16/08 04:09 PM
11/16/08 04:09 PM
Posts: 2,826 NY usa
540challenger
NY usa
I used the 78-91 style housing and thermostat in mine.
[Re: 540challenger]
#151588
11/16/08 08:36 PM
11/16/08 08:36 PM
Not to hijack, but are you plumbing this to the premagnum water pump? I still am looking for a neat looking way to hook that straight bypass fitting to the old style pump.
#151589
11/16/08 10:57 PM
11/16/08 10:57 PM
goldduster318
Lake Orion, MI
yeah, i'm doing that...I was just planning on using the normal bypass hose...figured it would work no problem.
#151590
11/17/08 12:37 AM
11/17/08 12:37 AM
Posts: 2,826 NY usa
540challenger
NY usa
THere are 2 ways of doing it
1. cut down the brass fitting a bit so the hose can make the bend.
2. I just purchased the odler la style fitting and trimmed back the hose a bit a fit on no problem
