Need a Radiator! Need Advice! #151552
11/16/08 11:08 AM
11/16/08 11:08 AM
United States
STLDuster Offline OP
United States
I am looking for a radiator for my '74 Duster. I have swapped in a 440/727 and have gotten it to the point to where I can start shopping for a radiator. What I had thought about doing was having my orginal (318-AC 2 Core Radiator) recored to a 4 core, but now the water pump inlet points to the driver side (opposite the outlet on the radiator). So now I am on the look out for a new radiator. I was looking at the Summit Universal Radiators, Jegs, and E-bay (I don't know about some of the ones on ebay). I have 30" in between my frame rails and sheet metal modifaction is not a big deal to fit a really big honking one in there. But I was starting to get confused and a little unsure, the tallest radiator I could find (in the aluminum univerals) is about 19" to 20". My stock radiatior is 22". Then there is downflow and crossflow? I am I wrong in thinking that the stock radiator is a downflow? I would really like to stick with that style, from what I have read I really wont gain anything by going to a cross flow radiator?
Any help or advice is greatly appreciated!
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Need a Radiator! Need Advice! [Re: STLDuster] #151553
11/16/08 11:18 AM
11/16/08 11:18 AM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
I find the US Radiator copper and brass units to be real nice. They fit like OE, but have a couple options to upgrade the efficiency of the core.
Re: Need a Radiator! Need Advice! [Re: BergmanAutoCraft] #151554
11/16/08 12:45 PM
11/16/08 12:45 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Thats what I ended up buying for my Dart. Dropped
my temps by 40 degrees!
Re: Need a Radiator! Need Advice! [Re: STLDuster] #151555
11/16/08 11:16 PM
11/16/08 11:16 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
I believe 440 Source has a pump housing which will let you use the passenger side outlet on the radiator.
Re: Need a Radiator! Need Advice! [Re: Michael] #151556
11/16/08 11:25 PM
11/16/08 11:25 PM
California, USA
P
Phil Saran Offline
Phil Saran  Offline
P
California, USA
Any competent radiator shop can move your
lower outlet to the othe side if that is
what you need. Last one I had done included
replacing the outlet to the bigger size
for about $35 total.
I have a 3 row A/C radiator in my 74 Duster
with a 383 motor.
Phil Saran Parker, Colorado
Re: Need a Radiator! Need Advice! [Re: STLDuster] #151557
11/16/08 11:37 PM
11/16/08 11:37 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
if you have the coin
Be Cool Radiators work and fit really well
they have the trans cooler built in
and customer service is excellent
have been running mine since 2004
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Need a Radiator! Need Advice! [Re: STLDuster] #151558
11/17/08 12:48 AM
11/17/08 12:48 AM
United States
United States
Thanks for the advice!
What do you guys think of these?
http://cgi.ebay.com/ebaymotors/70-71-PLY...sQ5fAccessories
Re: Need a Radiator! Need Advice! [Re: STLDuster] #151559
11/17/08 09:28 AM
11/17/08 09:28 AM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
Wow. Those SEEM to be the deal of the century. I just paid $300 to get my 26" radiator redone. I would have taken a chance on one of these though.
Re: Need a Radiator! Need Advice! [Re: farmington] #151560
11/17/08 09:38 AM
11/17/08 09:38 AM
NY usa
540challenger Offline
NY usa
LoL i would try it i spent over $700. on mine thru jegs for s "stock replacemnt style and it doesn.t have provisons for a stock shourd .
Re: Need a Radiator! Need Advice! [Re: STLDuster] #151561
11/17/08 09:52 AM
11/17/08 09:52 AM
Wausau Wisconsin USA North Ame...
radiatorman Offline
radiatorman  Offline
Moving the lower connection is a piece of cake. Have yours recored. It might not be cheaper than the universal aluminum ones, but it will cool better and in my opinion, look better. Good luck!!
Bob Schirmer
Glen-ray Radiators
1.800.537.3775
1.715.842.3352
Re: Need a Radiator! Need Advice! [Re: STLDuster] #151562
11/17/08 02:40 PM
11/17/08 02:40 PM
ILL
Greentween Offline
Greentween  Offline
ILL
I have that one. Works good,and I'm happy with it. The welds are rough and made in china. If those 2 dont bother you, go for it
