another clutch question #1515514
10/11/13 04:30 PM
10/11/13 04:30 PM
yellow70charger Offline OP
whats the difference other than price?
Race version
http://www.jegs.com/i/Hays/490/49-220/10002/-1
Street Strip ?
http://www.jegs.com/i/Hays/490/40-220/10002/-1
Can I use the race one on the street? Is this not adviseable
wouldn't a race clutch last longer cause its made of better materials?
Re: another clutch question [Re: yellow70charger] #1515515
10/11/13 05:45 PM
10/11/13 05:45 PM
I ain't a clutch guy so take this with a grain of salt & just consider it more of a BTT. I'd think the race one would be grabbier and or wear out faster either from how it's constructed or the type of material used (or both)
Re: another clutch question [Re: yellow70charger] #1515516
10/11/13 09:08 PM
10/11/13 09:08 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
That race unit will be okay on the street
Although the Centerforce unit I have would work better
Gus
64 Plymouth Savoy
Dana 60
Re: another clutch question [Re: fourgearsavoy] #1515517
10/11/13 11:09 PM
10/11/13 11:09 PM
This guys awesome
Re: another clutch question [Re: yellow70charger] #1515518
10/11/13 11:19 PM
10/11/13 11:19 PM
Race version
Street Strip ?
http://www.jegs.com/i/Hays/490/40-220/10002/-1Can I use the race one on the street? Is this not adviseable
Most race clucth discs normally don't have a marcel(thin wafer) spring between the two halves of the clutch discs, street discs do The race disc neeeds to be in all the way or let out all the way, they usually won't slip easily when letting the clutch out If you look closely at both pictuures there are a lot of differences in them, the race disc has lightening holes on the metal center, different amount of the center shock springs and so on. Probally different clutch lining also
Re: another clutch question [Re: fourgearsavoy] #1515519
10/12/13 09:28 AM
10/12/13 09:28 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree with Gus.The CF is a great clutch.Has decent street manners and hooks great.Rocky
Chrysler Firepower
