Belt noise v6 #151338
11/15/08 03:05 PM
11/15/08 03:05 PM
ohio
dragon Offline OP
dragon  Offline OP
ohio
2002 dakota has a noise coming from belt or pulley truck has 55000 mile replaced belt at 54000 and it made a little noise sounds like it is comming from the belt tensioner has anyone had this problem the noise has gotten a lot louder Thanks
Re: Belt noise v6 [Re: dragon] #151339
11/15/08 09:35 PM
11/15/08 09:35 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
i have had a lot of trouble with noisy belts on my 97 dak. is that the reason you changed the belt in the first place? i've tried auto zone cheapes and higher priced ones from napa,finally put original belt back on to stop noise. i think my noise started after replacing water pump. have you changed any thing other than the belt?
Re: Belt noise v6 [Re: pushbutton] #151340
11/16/08 08:06 AM
11/16/08 08:06 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I get my belts at the Mopar house. No noise. You could get a piece of heater hose, put one end up to your ear and move the other end around to the belt driven components on your engine. You'll find your noise. I'd try a good belt first, though.
