Re: Passing Gear Linkage [Re: JohnRR] #151166
11/16/08 09:56 PM
11/16/08 09:56 PM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
You either have the wrong manifold or the linkage on incorrectly , if they are the right manifolds the linkage rod will not hit it .
This is starting to sound like there is a problem with the shift linkage and not the kickdown linkage. He said passing gear linkage originally so I'm assuming Throttle Valve linkage but I find it hard to believe that stuff could get in the way. Maybe there's a problem in the bellcrank area of his shift linkage.
Does that sound right ,Joe?
Don.
Re: Passing Gear Linkage [Re: MoparDonny] #151167
11/30/08 09:55 PM
11/30/08 09:55 PM
Sonoran desert, Arizona, USA
moparjo68 Offline OP
I'm not sure I'm calling this linkage by its proper termanology. I thought it was the passing gear linkage but it may be called the kickdown linkage. Anyway, I managed to locate the linkage from a '70 Chrysler and tried it. It doesn't hit or even come close to the exhaust manifold. Hip hip, horray!!!!
