gas tank behind the seat #1510807
10/01/13 04:42 PM
10/01/13 04:42 PM
Friendly, WV
wedgeheaded Offline OP
Friendly, WV
When did they stop putting the tanks behind the seat? I looked at a 77 D 100 yesterday with dual tanks. The first was in the cab, the other was where I expected to find it. Everything looked factory. I was just surprised to find a tank in the cab that late in the 70s.
Re: gas tank behind the seat [Re: wedgeheaded] #1510808
10/01/13 04:46 PM
10/01/13 04:46 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I've heard 77/78
Re: gas tank behind the seat [Re: wedgeheaded] #1510809
10/01/13 04:55 PM
10/01/13 04:55 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
My Dad worked for a Canadian Chrysler dealership in the 70's. He had thought they stopped putting them in around the end of 74 but then I bought a 75 with one. They seem very rare after the mid 70's but I am guessing it was somewhere on the option sheet until the body style changed.
Re: gas tank behind the seat [Re: CTD5.9] #1510810
10/01/13 05:13 PM
10/01/13 05:13 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
It was standard in 73. 74 they started putting them under the bed. My 74 is saddle tank. This is for Standard cabs. My 73 Clubcab had saddle but filled through the cab. I've had a 75 Cab that was in cab aswell. Its hard to really say when they quit or ran out. None of my 75 up trucks have ever had in cab tanks and I've owned over 40 and that's just in the last 12 yrs
Re: gas tank behind the seat [Re: 76dodgeboy] #1510811
10/01/13 05:24 PM
10/01/13 05:24 PM
Friendly, WV
Friendly, WV
Well, I didn't actually see the tank behind the seat. I caw the cap on the side of the cab and assumed there was a tank attached behind the seat. After reading the last post, I wish I'd looked closer.
Re: gas tank behind the seat [Re: wedgeheaded] #1510812
10/01/13 05:46 PM
10/01/13 05:46 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Is it a clubcab?I have a 76 and 79 Clubcab and neither are in cab filler necks
Re: gas tank behind the seat [Re: 76dodgeboy] #1510813
10/01/13 06:34 PM
10/01/13 06:34 PM
Friendly, WV
Friendly, WV
Short cab, short wide bed.
Re: gas tank behind the seat [Re: wedgeheaded] #1510814
10/01/13 07:05 PM
10/01/13 07:05 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
And you said dual tanks. So one in cab and A front saddle tank than like most 70s are?
Re: gas tank behind the seat [Re: 76dodgeboy] #1510815
10/01/13 08:23 PM
10/01/13 08:23 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Harry your 75' ClubCab at my place came with a saddle tank
My old 74 reg cab had a in cab tank
I had a 75 Camper 9000 ClubCab & it had in cab & saddle tanks that filled through one filler in the cab
Re: gas tank behind the seat [Re: wedgeheaded] #1510816
10/01/13 08:32 PM
10/01/13 08:32 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
I bought a new '74 W200, reg cab and long bed.
It had just one tank, underneath the truck, I thought that was the first year ... also a new '76, same thing.
It takes gasoline to interest me.
Re: gas tank behind the seat [Re: VL21] #1510817
10/01/13 08:41 PM
10/01/13 08:41 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
My 78 D300, 73 W200, 75 W100 had a in-cab and a saddle tank.
My 73 D100 Cub Cab had a saddle tank but the filler tube went through the cab.
My 73 D100 SB only had a cab.
My 80 D150 only has a saddle tank.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: gas tank behind the seat [Re: 76dodgeboy] #1510818
10/01/13 11:35 PM
10/01/13 11:35 PM
Friendly, WV
Friendly, WV
Dual tanks with a factory switch, yes. One fill cap on the cab, the other to the front of the bed, same side. Someone suggested that the cab fill tube might run to a saddle tank instead of a tank behind the seat. I'd not thought of that. I didn't look behind the seat for a tank. I just thought it was there, and might have been. I don't know.
Re: gas tank behind the seat [Re: wedgeheaded] #1510819
10/02/13 10:27 AM
10/02/13 10:27 AM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
My 78 D300 had the in cab tank, since it was a cab & chassis. The regular frame tank wouldn't work on these trucks, one needed the left side of the frame open for a trans mounted pto (to power the hoist) and the other side for exhaust.
I used a rear tank from a 77-78 club cab shortbed truck when I restored mine. The donor truck was dual tanks, one in the standard frame location, the 2nd one in the rear where the spare tire would be.
Ed
Re: gas tank behind the seat [Re: wedgeheaded] #1510820
10/03/13 01:56 PM
10/03/13 01:56 PM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
I had a govt BLM power wagon crew cab, and it had dual tanks, one in cab, and one in fram in the usual spot. My truck was an 80...so I am guessing special placement per the feds...
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
