66 Belvedere - Bogging Down #1510153
09/30/13 06:18 PM
09/30/13 06:18 PM
Northeast
edl Offline OP
edl  Offline OP
Northeast
have original 426 engine - pretty stock
recently worked on timing - got that straightened out and car ran fine all summer
alternator went so replaced that a couple of weeks ago - things were fine
starter motor died - replaced that - things were fine
replaced freight train of a fuel pump with a really nice quite holley (pn 12-125) - car seemed to run fine - but now it is bogging down
so i'll be driving along and notice that it drops in revs a little now and then - and if i get on the accelerator i get a mixed response - so me accerleration...some bogging -
the pump at idle purrs right along - i would think that would be the obvious thing since that is what just changed
but if it weren't, what else might be causing this?
thanks as always to the moparts sleuths!!
Re: 66 Belvedere - Bogging Down [Re: edl] #1510154
09/30/13 07:07 PM
09/30/13 07:07 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
How much fuel pressure do you have at the carb? The new pump may be producing too much pressure causing the carb to flood or too little cuasing fuel starvation. Is there any reason you can't just run a stock mechanical pump?
Re: 66 Belvedere - Bogging Down [Re: stumpy] #1510155
09/30/13 09:50 PM
09/30/13 09:50 PM
IN
ahy Offline
ahy  Offline
IN
Agree a fuel pressure check is a god idea. A barb "T" on the carb supply line and simple gauge is easy to rig up.
I don't know the original carb... if Holly type, look for 5-7 PSI. If thermoquad/Edelbrock type it wants under 5 psi to prevent overpowering the float/needle. A regulator may be needed.
Re: 66 Belvedere - Bogging Down [Re: ahy] #1510156
09/30/13 10:27 PM
09/30/13 10:27 PM
Northeast
edl Offline OP
edl  Offline OP
Northeast
thx guys
the pump is rated at 7psi max - holley's literature that came with the pump says:
REGULATOR
Not Needed
go figure - i'll rig one up and see what pressure i am getting...
Re: 66 Belvedere - Bogging Down [Re: edl] #1510157
09/30/13 11:45 PM
09/30/13 11:45 PM
More detail please on what it is doing, how much throttle, how it's acting etc
Re: 66 Belvedere - Bogging Down [Re: RapidRobert] #1510158
10/03/13 11:34 PM
10/03/13 11:34 PM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
Why arent you running a stock mechanical fuel pump?
Re: 66 Belvedere - Bogging Down [Re: ogopogo] #1510159
10/04/13 09:14 AM
10/04/13 09:14 AM
Northeast
edl Offline OP
edl  Offline OP
Northeast
that's the way the car was set up when i bought it so i just used it that way - the old pump was on its last leg and i replaced it - seemed like the path of least resistance - had a hollley red in before - now a holley 12-125
Re: 66 Belvedere - Bogging Down [Re: RapidRobert] #1510160
10/04/13 09:17 AM
10/04/13 09:17 AM
Northeast
edl Offline OP
edl  Offline OP
Northeast
i didn't play with it too much b/c i was about 30 minutes from home with the kids and didn't want to have get a tow - was on the highway when i first noticed it - going about 60 - driving steady - car lost a little power...came back - did it again - steadied out - seemed to go away - found that if i got on the accerator at all, it would bog - so i just stayed steady and increasingly slower as i went from highway to side streets until i got home - haven't driven it since - haven't had a chance to test the pressure yet
Re: 66 Belvedere - Bogging Down [Re: edl] #1510161
10/04/13 11:11 AM
10/04/13 11:11 AM
It sure sounds like classic fuel starvation like something substantial plugged alot of the flow especially with it still starving that bad on the side streets (low rpm). I'd check the pump for flow then the pickup for restrictions & the filter(s). I'd also go in the carb(s) & take off the clusters (afb/eddys I'm assuming) & flush em with brake kleen
Re: 66 Belvedere - Bogging Down [Re: RapidRobert] #1510162
10/04/13 12:42 PM
10/04/13 12:42 PM
Northeast
edl Offline OP
edl  Offline OP
Northeast
thanks RR - maybe i loosened something and clogged up the works when i changed pumps...i'll start chasing
Re: 66 Belvedere - Bogging Down [Re: edl] #1510163
10/04/13 10:29 PM
10/04/13 10:29 PM
Yeah you might pull all 8 clusters & give em a good blast & I always replace em in the same recess they came out of. I lube the threads with oil on the carb top mini bolts as they go into aluminum. That'd have to be a hell of a restriction (in the rest of the fuel system) to make it act like that at low speed (assuming it is fuel starvation) so I'd start with the carb. Holler how it turns out
Re: 66 Belvedere - Bogging Down [Re: RapidRobert] #1510164
10/08/13 11:18 AM
10/08/13 11:18 AM
Northeast
edl Offline OP
edl  Offline OP
Northeast
"cluster" is the right word - couldn't get it to start this weekend - didn't have time to do any cleaning though...
Re: 66 Belvedere - Bogging Down [Re: edl] #1510165
10/08/13 04:25 PM
10/08/13 04:25 PM
Cab_Burge Online work
Cab_Burge  Online Work
Mechanical fuel pumps suck a lot harder than the electric ones do, it sounds like maybe you have a fuel problem with vapor locking I would check the fuel tank pickup filter and sock and all the rubber lines in the fuel system for possible leaking under suction I have seen the stock pickups(in older cars) be plug up inside them with solid guck
Re: 66 Belvedere - Bogging Down [Re: Cab_Burge] #1510166
10/08/13 04:34 PM
10/08/13 04:34 PM
Northeast
edl Offline OP
edl  Offline OP
Northeast
OK Cab - I will - thanks
Re: 66 Belvedere - Bogging Down [Re: ogopogo] #1510167
10/11/13 01:21 PM
10/11/13 01:21 PM
Northeast
edl Offline OP
edl  Offline OP
Northeast
thinking about this question more...why did the previous owner (or why would any owner) go with an electric pump? - are there known issues with the hemi engine and the mechanical pump?
