Under cowl insulation - what glue did you use?
#1508557
09/27/13 05:56 PM
09/27/13 05:56 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Well that is pretty much the question. I got my under dash insulation from Detriot today and I plan to install it in the AM, just curious what produced the best results in glueing it down.
Thanks in advance, Kevin
Careful, your character's showing!
Re: Under cowl insulation - what glue did you use?
[Re: AAR#2]
#1508559
09/27/13 06:05 PM
09/27/13 06:05 PM
mopar346
Thank you, where did you get it?
[Re: 6bblgt]
#1508566
09/28/13 09:21 PM
09/28/13 09:21 PM
mopar346
I wondered about the old 3M trim adhesive but it has been awhile since I used any. I may have to go that route since I don't seem to be able to source the Weldwood locally. Maybe some others will chime in tonight.
Did you use the 77 on your with good success?
[Re: Dodge33]
#1508569
09/29/13 11:25 AM
09/29/13 11:25 AM
mopar346
I take it that it is pretty much the same as the old 3M spray adhesive, sounds like it applies the same way and it use to be good stuff. Temp should be fine I'm in Florida, mid 80s today I think.
[Re: mopar346]
#1508570
09/29/13 08:45 PM
09/29/13 08:45 PM
mopar346
I found the 77 as well as the old 3M super trim adhesive. I used the old stuff and put installed it today. It worked like a champ, I will check it after a few days to make sure it holds properly but I have no concerns recommending it at this point. It is readily available and most parts houses although a little pricey as it has always been ($22 a can). The 77 was cheaper but I have used the old stuff with great success in the past so I went that wasy.
