mud truck 440 engine help. #1508315
09/27/13 10:44 AM
09/27/13 10:44 AM
junction city oregon
V
viperblue72 Offline OP
V
I have a fresh short block 440 with 2355 pistons and rpm rods, also stealth heads, rpm intake, 1 7/8 headers. I don't really know how to build a mud bog engine, but I mostly need help with camshaft choice. I am thinking the mp 528.
Also, it's a short wide pw with 38.5 swampers, and will weigh between 45-4700 pounds.
Also the converter will be a 2k stall for now, but will step up to a 3k or more later.
Thoughts?
Re: mud truck 440 engine help. [Re: viperblue72] #1508316
09/27/13 10:45 AM
09/27/13 10:45 AM
V
V
Oh and I forgot to mention, there is a chance I will put a 100 shot on it eventually as well.
Re: mud truck 440 engine help. [Re: viperblue72] #1508317
09/27/13 11:29 AM
09/27/13 11:29 AM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
What gear are you running? and what kind of mudding? lots of low down crawling or some possibly faster racing type mudding? and what kind of horse power are you looking for
Re: mud truck 440 engine help. [Re: CTD5.9] #1508318
09/27/13 11:55 AM
09/27/13 11:55 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
You normally want a cam that has the same rpm power range as the other parts. 2k stall is kinda low IMO
Re: mud truck 440 engine help. [Re: viperblue72] #1508319
09/27/13 08:38 PM
09/27/13 08:38 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Get a converter with an anti-ballooning plate
