Re: best way to remove t bars- for good!
[Re: dartman366]
#1507150
09/29/13 01:10 AM
09/29/13 01:10 AM
Posts: 781 wine country
8urvette
wine country
I started out small by just replacing the upper controll arms and added coilovers and left the stock lower controll arms in place untill later, as far as the torsion bars, I just removed them and then drilled and tapped the mounting stud that go's into the K member inside the hex hole where the front segment of the T bar was and used a grade 8 bolt and a thick washer that just fit the hex hole and loctited it into place,,ran it that way for years untill I was able to afford to replace the lower controll arms and radius rods, I am still using the stock K member to this day, yes it's been lightened some and modified to fit my oil pan.
i guess i need to get under my car, because when i read this, then re read i am just lost without pics. but it definitely sounds do able... i think.
