best way to remove t bars- for good!
#1507130
09/24/13 09:43 PM
09/24/13 09:43 PM
Posts: 781 wine country
8urvette
wine country
Im kicking around the idea of tubular k along with tubular LCA's and UCA's. I see Bondo bobs stuff looks nice, and i know there is huge debate on whose system is best and who's is junk.... I don't want to hear that.
I am wondering, can i start small, replace the control arms, and remove the t bars, then at a a later date move to the k frame.
Ideally I want a tube k, with a mustang II rack, tube uppers, and lowers with some nice coil overs. But i don't have 4k to throw at it right now.
so how do i start small???
I am under the impression i must go to tube uppers to clear any coil over. and once i have the coil over in, something different has to be done to the lower to remove the torsion bar for good. I don't know, just what i was told a while ago.
so maybe i should start by asking, " what must be done to eliminate my torsion bars"??
Re: best way to remove t bars- for good!
[Re: 8urvette]
#1507132
09/24/13 11:19 PM
09/24/13 11:19 PM
Posts: 209 Mesa, Arizona
6pak2go
Mesa, Arizona
<quote> I am wondering, can I start small, replace the control arms, and remove the t bars, then at a later date move to the k frame? <end quote> Here's an option I've just run across. I have no idea of the quality. http://www.dillingerchassis.com/store/
Robert R Mesa, AZ 70 Challenger R/T 440-6 4-Sp Cruiser 67 Barracuda FB 540 4-Sp Strip/Street and Drag Week
[Re: 6pak2go]
#1507134
09/24/13 11:34 PM
09/24/13 11:34 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
if you're in need Robert give Comp Chassis a call in Glendale. Mike fabbed up my tube K for the Duster. They did work on our old car so I didn't even think twice on who to go to with the Duster.
[Re: J_BODY]
#1507135
09/25/13 07:18 AM
09/25/13 07:18 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
To simply remove the torsion bars. On the lower control arm you can make a rear support collar that goes around the socket the torsion bar slides into. You still need a coil over shock with mods to the shock tower to stiffen it up. Unless you want to ride on the stops.
Leon
[Re: 70AARcuda]
#1507139
09/25/13 08:54 PM
09/25/13 08:54 PM
Posts: 654 ohio
dbran451
ohio
what happened I thought he made some nice looking stuff reasonable
John Dillinger is not currently making any chassis parts....
[Re: modelmakerinc]
#1507140
09/25/13 09:39 PM
09/25/13 09:39 PM
Posts: 9,871 MI, usa
dvw
MI, usa
Not to hi-jack but, would this bar tied to the firewall, welded to the cage, frame rail and shock tower have enough support to run the front coil-overs?
It wouldn't scare me. Doug
[Re: dvw]
#1507141
09/25/13 09:58 PM
09/25/13 09:58 PM
Posts: 52,972 Romeo MI
MR_P_BODY
That wouldnt bother me either... BUT on the street I would had a bar(maybe 2) on either side of the tower down to the lower frame rail for added strength.. put them in on a angle to follow the tower.. but thats just me... I know for the street you want added strength at least on Mich roads(they suck big time)... I worry about my strut suspension on our roads
[Re: MR_P_BODY]
#1507142
09/26/13 01:38 AM
09/26/13 01:38 AM
Posts: 34,942 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
On my 64
We had Tube A-arms , upper and lower ..
Made a piece to support the lower A-arm
Ran a "stock" K-frame , trimmed a bunch
Qa1 coil overs ..
and way stiffer than recommend springs , had to ..
long story ..made most of it ourselves ..
Had to re-engineer a bunch of what a kit someone sold me , it was poo, he no longer is in business
it all looked good but , would not work like he thought ..so, we tossed most of it away ..
After a couple months working on it off and on, worked like a champ
I'm not 100% sure there is a bolt and go set up out there now
(alterkation looks like best option but , its $$)
Bobs stuff seems like it works right too, but again ??.never bought so, don't have 1st hand knowledge of it
I do think you can improve on stock but .. ??
Here is the car once we got it working right
[Re: bigdad]
#1507143
09/26/13 09:43 AM
09/26/13 09:43 AM
Posts: 361 Canada
onig
Canada
Hey bigdad, any pics of your front end.
69 Dart
[Re: onig]
#1507144
09/26/13 10:14 AM
09/26/13 10:14 AM
dartman366
Mt. Vernon, Ohio
I started out small by just replacing the upper controll arms and added coilovers and left the stock lower controll arms in place untill later, as far as the torsion bars, I just removed them and then drilled and tapped the mounting stud that go's into the K member inside the hex hole where the front segment of the T bar was and used a grade 8 bolt and a thick washer that just fit the hex hole and loctited it into place,,ran it that way for years untill I was able to afford to replace the lower controll arms and radius rods, I am still using the stock K member to this day, yes it's been lightened some and modified to fit my oil pan.
[Re: onig]
#1507145
09/26/13 07:37 PM
09/26/13 07:37 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Yeah,somewhere ...
Might take me some time to dig them up
[Re: dartman366]
#1507150
09/29/13 01:10 AM
09/29/13 01:10 AM
8urvette
wine country
i guess i need to get under my car, because when i read this, then re read i am just lost without pics. but it definitely sounds do able... i think.
