Page 2 of 3 1 2 3
Re: Orange box ??? #150698
11/14/08 01:45 PM
11/14/08 01:45 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Correct me if I'm wrong, but the ballast only controls the coil, the box uses a full 12V. And as far as the orange box, the old ones were great, the past 10 years though, they were junk and wont last no time.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: Orange box ??? [Re: 70dart360] #150699
11/14/08 01:47 PM
11/14/08 01:47 PM
the negative side of the coil is triggered inside the box. That is what that transistor does. It is a switch. It closes and opens the negative side of the coil when the magnetic pick up in the distributor tells it to.
So ya, more voltage and current to the coil, the more power thru that transistor so it WILL get hotter. If the heat cant be disapated fast enough, it will blow or melt that potting material
Re: Orange box ??? #150700
11/14/08 02:56 PM
11/14/08 02:56 PM
For short runs any of the boxes will take full alternator voltage but will get over hot for crusing around. Stock boxes are limited to 5500 RPMs. The coil will also take short periods of full voltage. But will boil the oil if left on to long. When you put more voltage thru the coil it will produce a hotter spark. But none of them will put out more spark than is needed to jump the gap on the plug. Thats why we open up the gap when we have hotter ignition systems to make the coil fire more voltage. The better quality of box you use the better it will handle the extra voltage. Thats why FBO designed their Box and coil to take Higher voltage with out melting down. But they still need a resister to control the voltage on the street . I run their system on my race car a full voltage but then the car rairly runs longer than a few minutes. Also they use better Transister and circutry that improves the slew rate which is the time it takes the signal to travel thru the box and to the coil. That slew rate is high on the Mopar boxes thats why they retard the timing. All boxes do it some, but the better the circutry the lower the slew rate and the less retard. FBO also has timing kits that allow you to adjust the distributor mechanical advance with out welding the slots and can be installed or removed with out damaging the distributor the kit has 4 preset curves but can be filed to make multipul advances www.4secondsflat.com
Re: Orange box ??? #150701
11/14/08 08:04 PM
11/14/08 08:04 PM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
Are you familiar with the internet term "astroturfing"
Because , "sho enuff" that's what you are doing here, and frankly, I wish you would stop !!!
Re: Orange box ??? [Re: IronWolf] #150702
11/14/08 10:15 PM
11/14/08 10:15 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have used the same orange MP ecu since 1997. It was on my boys Dart and then when he got MSD I put it on my 63 when I put it on the road in 2006. I use a .75 ohm ballast and the old Acell Super coil. I shift my 63 at 6200 and trap about 6300 and it never misses a beat. I can also tell you my boys Dart did not run any faster when he put MSD on it. Here is where I have it mounted on my 63 with no problems. Ron
Re: Orange box ??? [Re: IronWolf] #150703
11/14/08 10:27 PM
11/14/08 10:27 PM
Astro turfing that is new to me. Sorry if my info isnt worthy of your superior intellect I was just offering some info. If my suggesting people that can help others is astro turfing then so be it. And that the following guy put a MSD on his sons car and it didnt make any differance supports my assumption about ignitions not putting out more than they need to to jump the gap.Makes MSD kind of worthless like people that critisize others to make them selves seem better.
Re: Orange box ??? #150704
11/14/08 10:40 PM
11/14/08 10:40 PM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
You are an astroturfer because you are pimping another's products online.
You are "probably" correct in assuming I have a superior intellect, as well.
Re: Orange box ??? [Re: IronWolf] #150705
11/14/08 11:39 PM
11/14/08 11:39 PM
70duster340 Offline
70duster340  Offline
My, don't we have a high opinion of ourselves!!!
Re: Orange box ??? [Re: 70RR383] #150706
11/15/08 12:14 AM
11/15/08 12:14 AM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Grab the chrome box. I had an orange box and it didnt even last a year. Even my buddy got a deal that was worse than that. He ordered a gold ecu from summit and the thing didnt even work!
Re: Orange box ??? [Re: 70RR383] #150707
11/15/08 11:52 AM
11/15/08 11:52 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
One of my FURD buddies also has a 85 power wagon.He asked me what the advantage of running the orange MOPAR electonic box over stock was.Is there any??Thanks
I would run the stock ECU. FWIW,I have never had any problems with any of the orange box ECU's I have used.
Nautilus Racing-
Re: Orange box ??? [Re: RapidRobert] #150708
11/15/08 12:06 PM
11/15/08 12:06 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
that settles it(for me). My next one is going in fromt of the radiator a little bit off to the side.
You will have to watch out for moisture penetration. They are mounted back there for two reasons, get them out of direct spray from rain and to have the fire wall sink some of the heat away from the transistor. Don't get alarmed if the transistor gets warm, it is supposed to. The output transistors in your AM radio get hotter and manage to stay alive. I used to carry a spare ignition module for fear the thing would die and leave me stranded. After 30 years, I can't remember where I put it. The original won't die. I think it is in the gap between the trunk extension and the fender, now that I think about it. I will have to look. Its in a sandwich bag.
Craig
Re: Orange box ??? [Re: denfireguy] #150709
11/15/08 12:21 PM
11/15/08 12:21 PM
Good point, it would certainly catch hell if I put it there. I'll have to rethink that.
Re: Orange box ??? #150710
11/15/08 02:55 PM
11/15/08 02:55 PM
WA 98043
thecarfarmer Offline
WA 98043
Astro turfing that is new to me. (big snip)
I had to go hit google. Even urbandictionary didn't have it. Stolen from wikipedia:
"Astroturfing in American English is a neologism for formal public relations campaigns in politics and advertising which seek to create the impression of being spontaneous "grassroots" behavior, hence the reference to the artificial grass, AstroTurf."
-bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: Orange box ??? [Re: thecarfarmer] #150711
11/15/08 03:01 PM
11/15/08 03:01 PM
"Astroturfing in American English is a neologism for formal public relations campaigns in politics and advertising which seek to create the impression of being spontaneous "grassroots" behavior, hence the reference to the artificial grass, AstroTurf." -bill
could you repeat that
Re: Orange box ??? [Re: 70RR383] #150712
11/15/08 03:18 PM
11/15/08 03:18 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
Orange box directly mounted to firewall since 1994 with no problems.
Re: Orange box ??? [Re: JonC] #150713
11/15/08 06:55 PM
11/15/08 06:55 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
i have my orange box mounted on core support inside right side under horns. i had one go bad mounted on right inner fender. also one time i had one loose it's ground.always good idea to make sure ground is good before tossing the box. by the way i'm new,so if i posted this wrong sorry.
Re: Orange box ??? [Re: pushbutton] #150714
11/15/08 07:54 PM
11/15/08 07:54 PM
You posted it perfect. Welcome aboard
Re: Orange box ??? #150715
11/16/08 01:45 PM
11/16/08 01:45 PM
Slew rate is important and can retard the timing if its bad enough.
That being said, Ive heard the hype of FBO but being the sleptic that I am (as well as my electrical engineering background), I'd need to see so me numbers that back it up. And by numbers, Im not talking about tests run by FBO to sell their products but actual independent test numbers. Also, I could easily figure out the slew rate and any reliability issues if I saw a schematic and a parts list of each box.
Seems like its a heavil;y gaurded secret.
I actually removed the circuit board from an ignition box several months ago. the circuit is pretty elementary. I'd love to compare it to the FBO box to see whats different (if anything)
Re: Orange box ??? #150716
11/16/08 05:56 PM
11/16/08 05:56 PM
Well you'll just have to Call them but I would imagine that he's as likely to give you his product specs as MSD Or Fast EFI or any other electronics company. As a electrical engineer I would assume you know what kind of things that would cause a increased slew rate.
I'm no engineer I use the product and it works But thats the last any of you will hear from me about that product or possibly any others since All I ever seem to get from You no it alls is greif when I try to participate on the site. So go stroke your egos and give someone else the greif I'm going back out to the shop and work on real cars.
Re: Orange box ??? #150717
11/16/08 07:27 PM
11/16/08 07:27 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I agree. Since slew rate is a function of the band width of the amplifier, even with using a discrete pass transistor I don't think it should be a serious issue even at 10,000 RPM. Electronics have come a long way since Chrysler designed the ignition circuit but amps with slew rates adequate to pass even 100,000 pulses per second were common in that era. But you are right, the outboard circuitry would be the limiting factor.
I am a proponent of using capacitive discharge ignitions such as MSD. It will limit the current through the ignition box whether it is orange, chrome, black or aftermarket. I am not endorsing MSD, in fact I have never used one. I have ancient Delta Mark 10s that I built in the 70s and they still work well for me but they have not been made for 25 years. But I am not racing, I just want a reliable ignition. I am also an amateur radio operator and know when an MSD is nearby (or just about any Ford) because my radios go ape with noise.
Just my experiences. I am not an engineer but I do have patents in circuits using op amps so I know enough to get in trouble.
Craig
Page 2 of 3 1 2 3
