Any successful Max Wedge-sized street/strip 440 builds?
#1506352
09/23/13 01:30 PM
09/23/13 01:30 PM
BradH
I'm interested in hearing how successful people have been in building 440 RB / 451 B (NOT 469++ strokers) street/strip combinations that use heads w/ Max Wedge-sized intake runners (Indy 440-1s, EZ-1s, MW'd SRs, Max Wedge Victors, etc).
I've met some people (car owners & engine builders) who have similar thoughts that I do that MW-sized ports are really too big for street/strip 440-451 engines (too little velocity, kills torque curve, need to rev pee outta them to make power, etc.). However, a couple of engine builders I've mentioned this to recently have said this isn't the way it has to be and suspect those build-ups used MW-sized heads that weren't prepped to be especially efficient for their runner volume (which IMO means didn't flow enough to justify the extra runner size).
Keep in mind I've been running 440 pump-gas combinations that have run mid-10s w/ standard-port aluminum heads and 11.0s w/ ported standard-size OEM iron heads, both using solid flat-tappet cams. My point of reference is a 3750# E-body w/ 4.10 gears, DOT-legal drag radials and a full exhaust system, so I don't know how something like a 3000# A-body w/ 4.56s and exhaust dumps before the rear axle would exactly compare.
Regardless, I'm interested in hearing what people have done and whether I should be more open-minded to such a build in the future.
Re: Any successful Max Wedge-sized street/strip 440 builds?
[Re: AndyF]
#1506357
09/23/13 04:32 PM
09/23/13 04:32 PM
BradH
... But do you really want to add more gear to your combo?
Nope, not and still expect to put it out on the highway at 65 MPH and drive 100+ miles to some of the farther away tracks.
[Re: BradH]
#1506363
09/23/13 09:28 PM
09/23/13 09:28 PM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
My build was a 4 inch stroke,4.350 bore RB but thought you might like to hear about it anyway, as it was a low rpm deal. 440-c bowl ported heads with 2.19 intake valves, 268@ .050 duration, .540 lift Hydraulic cam, 750 alky carb, (would be very close with E85) 12.5/1 compression. I shifted this thing all day at 6,000 rpm, tried 5800 once and it ran the same. Made enough power to push 3180 lbs to 10.10 at 132 mph. You could pretty much figure that the loss of 30 cubes would increase the needed rpm by the same percentage, or about 350 rpm. I am betting the reason my deal worked well was alky(torque) smaller cam, and a 5000 stall converter. If your stall is above the torque peak of the new MW combo, then it becomes pretty much a no brainer. The bigger ports will rule the day.
[Re: Moparpoor]
#1506364
09/23/13 10:48 PM
09/23/13 10:48 PM
BradH
I run a max wedge port 60 over 440 on pump gas with no problems.Indy ez head full cnc max wedge port,actually larger than.11.2 cr,small straight duration roller cam,holley hp 1000 carb. Bottom end is stock except for a girdle.Nothing fancy at all.3700#race weight give or take a few pounds. 6300rpm shift point 4.30 gear 29.5 tire.10.72 @126mph it will go faster if I wind harder no need though.
That's probably a good comparison given similar weight, but it would be interesting to know if your combination would pick up shifting at higher RPM.
As described, it's not running any quicker (actually a couple of tenths slower at the same 126 MPH) than what I've gone w/ lower-flowing standard-port heads, less CR, a solid flat-tappet cam, and (coincidently), shifting at the same 6300 RPM. I figure my 4.10s and 28" tires probably work out to comparable RPM / speed #s as your 4.30s and 29.5" tires.
[Re: BradH]
#1506365
09/24/13 12:46 AM
09/24/13 12:46 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
We built a 451 several years ago. At first it was with home ported Stage VI heads and an excellent street engine. Made 612 ft-lb and over 500 ft-lb laready at 2900 rpm, 649 hp peak power at 6000. Later the Stage VI's got replaced with mildly home ported Indy 440-1 heads and intake, all other stuff remained the same except the headers which were Hooker 2" primary A-body headers in the forst combo, and about 10" shorter customs in the next one. The new Max Wedge port engien made 713 hp, at 7300 rpm. It made less power than the std port engine until 5600 rpm, and under 4000 there was prastically no one at home compared tot he old combo.
Plynouth VIP '67 TT IC EFI
[Re: BradH]
#1506366
09/24/13 07:54 AM
09/24/13 07:54 AM
Posts: 126 Howell,MI
Moparpoor
Howell,MI
It does go quicker as mentioned. I just switched to a set of MT 275 drag radial so we will see how that pans out with the 4.30 gear.I might get a few passes in this sunday weather permitting. will update.
[Re: BradH]
#1506367
09/24/13 11:38 AM
09/24/13 11:38 AM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
What's your definition of street. Driving the family on vacation or 20 minutes to the track?
My combination I just put together is a MW CNC ported performer head with 10.5-1 440 and a 640 Scott Brown solid. It runs 10.90's so far with 4.10 and 29" slicks. I used a block that was already .060 and under my work bench for the 20 years so my build was far from ideal but needed to get a motor together with what I had on hand.
Personally I think the question is really what's the gain with MW ports on a 440? Just going by feel I don't think the MW ports are gaining me much HP and would run close to the same with std port heads. Ironically the block I used was from an old 526 build with cast iron heads and it only ran a .15 better than a 440 with the same heads so the heads where the limiting factor.
I have not street driven mine yet but just driving around the pits I don't expect any issues.
I have yet to tweak the timing or jetting on mine. The one thing I have done is play with the shift points from 6200 to 7000. 6400 is the quickest but there is little difference between the them.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: d7cook]
#1506369
09/25/13 04:35 PM
09/25/13 04:35 PM
BradH
So far it's been: - 93 pump gas - full exhaust system - capable of cruising (screaming at?) 65 MPH on the highway - limited street usage; primarily driving to the track - driving anywhere from 40 to 100+ miles to the track one way; I've even done a couple of multi-event 500-mile weekends
Car's best pass to date was a 10.52 @ 126.2 MPH w/ 1.45 60-fts on 27560R15 ET Street Radials and hitting 3755#s (with driver) on the track's digital scales.
Looking to chip off a few tenths w/ the new engine combination I'm working on currently.
[Re: AndyF]
#1506370
09/25/13 04:49 PM
09/25/13 04:49 PM
BradH
Brad - have you come to any conclusions yet?
Well... nobody's piped in with anything, so far, that makes me want to change direction from what I've done already. Jyrki's description of the difference from how his car ran first with Stage VIs and then with 440-1s fits is pretty close to what I'd have expected.
My friend Mike Hynes ("THESHAKERPROJECT") mentioned the last time we were driving back from some local cruise-in in The MoPig that the car didn't really feel any different on the street when I got it running mid 10s than it did back when it ran high 11s... it's just a lot faster when the throttle goes wide open.
I chose (and still choose) not to build stroker engines that are better suited to "big" heads, IMO. It's just another one of those trade-offs people need to consider. I'm sure I could find some more HP w/ "big" heads, but would still expect driveability to take a hit.
[Re: BradH]
#1506371
09/25/13 06:01 PM
09/25/13 06:01 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
Brad...I wish I had some info for you, but my 446" Indy SR motor hasn't been run down the track or street since I had the heads opened up to max wedge size. It's 14:1 and has a pretty nasty roller in it, so it wouldn't really pertain to you anyway. It sounds good though.
