Duster idler arm ? #150602
11/13/08 09:47 PM
11/13/08 09:47 PM
Anonymous OP
Anonymous OP
I have a 74 Duster that I'm rebuilding the front end (suspension) on and I was replacing the idler arm when I noticed the new Moog idler is a different shape (more S shaped) . Does this super seed the original part ? I've checked a couple of suppliers and I come up with the same part number that received . Thanks
Re: Duster idler arm ? #150603
11/13/08 10:37 PM
11/13/08 10:37 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Different aftermarket suppliers' idlers look different. I have seen some that have square cross section and look angular. Whereas the Moog was a round cross section and more S shaped.
You are fine. Run that good Moog idler.
FYI... some aftermarket idlers for 73-76 A-body have a plastic/urathane/delrin? inserts as bearings instead of the mood metal to metal bearing. The Moog is much better, last longer, more precise. I had on of those plastic ones and it got loose in less that 10K miles.
The Moog idler is on the bottom
Re: Duster idler arm ? [Re: autoxcuda] #150604
11/14/08 12:21 AM
11/14/08 12:21 AM
fort worth,tx
txterry2 Offline
super gas
txterry2  Offline
super gas
fort worth,tx
The zerk fitting is in a bad place.I had to cut a notch on the bracket to keep from busting the zerk on my 74 duster.
Re: Duster idler arm ? [Re: autoxcuda] #150605
11/14/08 07:00 AM
11/14/08 07:00 AM
Anonymous OP
Anonymous OP
I'll try and post some picks tonight but my concern is if you look straight down at the original idler as it would be mounted on the car the mounting points are parallel to each other but with the Moog idler the mounting points are off set by probably an inch and a half . I know the new pat will mount on the car but it seems to me the steering will be limited in one direction .
Re: Duster idler arm ? #150606
11/14/08 12:03 PM
11/14/08 12:03 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The real geometry is the imaginary line between the bushings. Which way the arm/connecting link goes doesn't really matter unless it hits something. A check to see if you have a mis-boxed arm is if the center link is not level to the chassis.
Re: Duster idler arm ? #150607
11/15/08 07:15 AM
11/15/08 07:15 AM
Jasper, Indiana
fastnos Offline
fastnos  Offline
Jasper, Indiana
You might even have one for a /6. The ones for a V-8 had more of a longer drop or 'dip" in the "S." It's to clear the oil pan without rubbing. Some people forget to change when they convert to a V-8, then run into some problems. They might have mis-boxed your part.
A True Hybrid: Burns Gas AND Rubber!
Re: Duster idler arm ? [Re: fastnos] #150608
11/15/08 11:04 AM
11/15/08 11:04 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
That is incorrect.
67-76 A-bodies get the same pitman, centerlink, idler arm, tie rods if they are /6 or small block. [edit] 68-72 /6 & smallblock gets a different centerlink, pitman, and idler than 73-76 like Gmachinedart noted. 67 /6 & smallblock A-body has a different idler (stud mounted) than the 68-72 setup.[/edit]
383 cars get different idler and in 67 a different pitman. Both of which Moog does not sell.
Please do not get taken by the crooks trying to sell you a V8 centerlink for your 67-76 A-body
Only 63-66 A-bodies have a different centerlink /6 to V8.
Re: Duster idler arm ? [Re: autoxcuda] #150609
11/15/08 11:32 AM
11/15/08 11:32 AM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
67-72 Had one centerlink, 73-76 different centerlink. I agree they they were all the same across engine options.
Re: Duster idler arm ? [Re: BergmanAutoCraft] #150610
11/15/08 06:56 PM
11/15/08 06:56 PM
Anonymous OP
Anonymous OP
i talked to tech at Jegs and I guess I have the right part , it supposed to be an improved design . Thanks for all the response .
