Re: Stage V Hemi Intake?
[Re: spk2go]
#150595
11/13/08 09:13 PM
11/13/08 09:13 PM
Posts: 213 florida
PJM
florida
[Re: AndyF]
#150600
11/14/08 11:34 PM
11/14/08 11:34 PM
Posts: 3,488 Annapolis, MD, USA
Vert
Annapolis, MD, USA
Yep. And that aircleaner base will cost significantly more than the manifold. but it fits perfectly. It includes the aluminum bar for fitting to carb stud and lid holes, otherwise they don't match up. Also, you'll need either the stock-looking but longer 2x4 fuel lines, or make yourself a custom set. I have a brand new stock-look set from Rick Cassell that I'd like to sell. They fit Edelbrock carbs. They fit perfectly, but not large enough for my horsepower. Only used to start the engine, zero miles. Filter, up-line, t-block, lines to carb, clip, front and rear carb fittings(they are different). If you decide to make up your own set of lines you'll need to use banjo-type fittings. Clearance is quite tight under the base. At least it is with Edelbrock carbs. Which carbs are you using? And what size hemi? BTW, Ray told me his single 4bbl intake and dominator was good for nearly 100 horses over the 2x4 Stage V on a mildly modified 528.
