column upper bearing MIA need dimensions #1503481
09/17/13 10:50 PM
09/17/13 10:50 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
For a 71 barracuda if it matters.Sizes or a number would be cool.Thanks guys.
Re: column upper bearing MIA need dimensions [Re: crowbait] #1503482
09/18/13 03:03 AM
09/18/13 03:03 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: column upper bearing MIA need dimensions [Re: crowbait] #1503483
09/18/13 12:46 PM
09/18/13 12:46 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Confirm Challenger1's number. It's used in several different columns and should still be available.
Re: column upper bearing MIA need dimensions [Re: crowbait] #1503484
09/18/13 06:29 PM
09/18/13 06:29 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Does anyone reproduce the outer seal for these?
Re: column upper bearing MIA need dimensions [Re: mopowers] #1503485
09/18/13 07:12 PM
09/18/13 07:12 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
Thanks for the number help guys.
mopowers
Do you mean the lower column boot/seal thing or a sealed upper bearing?
