70 Challenger: Front Steel Brake Lines
#1503348
09/17/13 09:10 PM
09/17/13 09:10 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
I broke one of the front pre-bent steel brake lines for my drum brakes. Where can I get these new? My local NAPA did not show them. Thanks
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: 70 Challenger: Front Steel Brake Lines
[Re: BDW]
#1503353
09/18/13 08:49 AM
09/18/13 08:49 AM
YO7_A66
Indiana
I looked up all three companies and I found Fine Lines was the closest to me, so I ordered the complete brake line set and got their Ebay pricing. The kit was in stock and I should have the lines before the weekend.
Thank you all for the replies.
[Re: Challenger 1]
#1503355
09/18/13 10:01 PM
09/18/13 10:01 PM
YO7_A66
Indiana
I removed the two front lines tonight and I ended up cutting the passenger line to get it out easier. This got me wondering how tough is it to install the passenger brake line with the engine in and all of the wiring along the fire wall? One more, how tough is it to install the front-to-rear one piece brake line since it goes thru the frame? Thanks
[Re: BDW]
#1503357
09/19/13 09:34 AM
09/19/13 09:34 AM
YO7_A66
Indiana
The reason that I had to cut it was due to the extra wiring that I have added along the years. The wires were layed over the top of the brake line and I did not want to take a chance of damaging the wires, so I cut the brake line. I am hoping that I can run the new line under all of the wiring and slide it thru the back of the engine. I don't mind bending it if needed, but it sure looks like it will be a pain to get that line in there. Thanks for the reply.
How hard is it to to install the front-to-back brake line? Any hints for me? There are allot of turns to this line and it goes thru the frame rail in one area. Thanks again.
[Re: YO7_A66]
#1503358
09/19/13 09:47 AM
09/19/13 09:47 AM
Challenger 1
Cincinnati, Ohio
Easy actually, I did it on my 74 last summer. Stick it in from the rear and it goes in place easy. Same with the right front, it'll go in, no worry's. I put in all three for a hemi when I did mine, that way I have a return and 3/8" feeding the fuel pump up front on the motor.
My tank got painted black years ago by me. I took this opportunity to repaint it silver. I believe it reflects the heat better that way to keep my fuel cooler. Made sure my tank was clean inside, it was. This tank is my original 1974, it sat with racing gas in it for 18 years and the car never moved. Racing gas and lead is so good for your fuel system. Old electric wire for the stupid electric fuel pump that I tried years ago.
[Re: BDW]
#1503359
09/19/13 10:04 PM
09/19/13 10:04 PM
YO7_A66
Indiana
I received the Fine Lines brake kit one day after ordering! I was able to get all four front lines installed tonight. I was not expecting the two short MC to distribution block lines, but they are installed and fit with some miner tweaking. The drivers side was installed in just a couple of minutes. The passenger side was a little tougher but it went in with less issues than I expected. I installed it from the passenger side with a few minor bends. Once I had the passenger side located and snug, the drivers end just needed a couple of tweeks and it was in. I too had to do a little tweeking once it was in to clean up the looks at the fire wall. But overall, the four front stainless lines are in and look good. Props to Fine Line on the fitment of the front kit. I will install the three rear lines this weekend. Thanks for the replies.
