Rear window leaking in 07 Hemi Ram...Anyone else? #1501692
09/15/13 11:31 AM
09/15/13 11:31 AM
illinois
bigblk66_coronet Offline OP
illinois
Just noticed this morning that the rear window in my 07 Hemi quad cab ram in leaking from above the passenger side. Looks like its about a foot long or so. Anyone else having problems with this? Anyone know how epensive it would be to fix? .Thanks Joe
Re: Rear window leaking in 07 Hemi Ram...Anyone else? [Re: bigblk66_coronet] #1501693
09/15/13 12:13 PM
09/15/13 12:13 PM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
You may want to reseal the third brake light first. They are prone to leaks especially when they have been removed for bulb replacement. Then run a water hose over it to check for a leak. If there is a leak at the window, your local glass shop should be able to either ad sealer or cut the glass out and re-urethane it in.
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
