Re: 750 carbs on 700hp motors
[Re: rt66jim]
#1501042
09/15/13 12:09 AM
09/15/13 12:09 AM
Posts: 8,042 Mt Morris Michigan
mopar dave
Mt Morris Michigan
I should be at a 1.44 in relation to my best 10.39@131. so,what do you think needs attention, vert, rear gear or trans gear or is the car just too damn heavy?
[Re: mopar dave]
#1501043
09/15/13 12:41 AM
09/15/13 12:41 AM
Posts: 11,720 Portage,michigan
B3422W5
Portage,michigan
Car isn't to heavy to not 60 foot better. I went 1.43 on leafs running Eddie heads and a flat tappet when it weighed 3450 and ran 10.70's. Just didn't have enough steam past 1100 feet or so. That combo was 11.8 compression. You have about a tenth in 60 foot that is possible to be picked up, IMO.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: mopar dave]
#1501045
09/15/13 09:38 AM
09/15/13 09:38 AM
BradH
I should be at a 1.44 in relation to my best [Email]10.39@131.[/Email] so,what do you think needs attention, vert, rear gear or trans gear or is the car just too damn heavy?
I know it's an apples-to-oranges comparison, but my 440 Challenger @ 3750#s pulls 1.45-1.46 60s on 275R6015 DOT drag radials w/ 4.10s and a 4500-stall 'vert.
I'm not sure if you're under-geared for your torque curve or the converter hits "soft" or ???, but I'd expect you should be able to pull better 60s than my street/strip ride. You've got 5 MPH on top end over mine, yet mine has run solidly in the 10.5s w/ that much less MPH.
Simply trying to offer more food for thought...
