750 carbs on 700hp motors
#1501000
09/14/13 01:26 AM
09/14/13 01:26 AM
Posts: 8,042 Mt Morris Michigan
mopar dave
Mt Morris Michigan
how do people get 750 carbs to support 700hp? I had a conversation today with john calvert. he tells me my poor 60' is not the fault of the chassis as it has no tire spin on launch. he suggests a smaller carb than my 950 bigs. john says his 700hp motor in his mustang has a 735cfm holley on it and runs 9.56@136. how is that possible?
Re: 750 carbs on 700hp motors
[Re: mopar dave]
#1501003
09/14/13 08:03 AM
09/14/13 08:03 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If that car that made 700 hp with a 735 cfm carb was a stocker motor, then it has the ultimate in tricks to make power in the first place. There is a whole lot of improvements that will help reduce drag that aren't often done in a bracket build, which basically sets free a lot of power, thereby making a too small for the application carb look good. Another thing to consider is the carb fuel curve, and if the way it atomizes fuel is right for your application. Some carbs don't atomize fuel properly for certain combinations. Every motor build and its application is a bit different, and sometimes there is good power to be found in just a different carb, even of the same size. I haven't done much with carbs, but built a 475 motor using a juice cam and unported 440-c heads made over 600 hp on alky using a box stock Holley 750 alky carb. For what it was, it ran very well. A much bigger carb might have shown as much as 40 hp improvement though.
[Re: BradH]
#1501007
09/14/13 10:49 AM
09/14/13 10:49 AM
Posts: 11,720 Portage,michigan
B3422W5
Portage,michigan
Its rare in a smallblock stroker motor for large carbs not to show ET gains over smaller carbs. I have tried 5 or 6 different carbs on various stroker motors and found almost all the time the motor always liked the bigger carb over the smaller carb. Lone exception being a 1025rs race demon ET'ed as well as a custom 1100 dominator did. 950 is a very solid choice on a mid range stroker like you have.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: mopar dave]
#1501010
09/14/13 11:23 AM
09/14/13 11:23 AM
B3422W5
Portage,michigan
Dave.....if you don't mind what is your exact combo again??
[Re: B3422W5]
#1501011
09/14/13 11:28 AM
09/14/13 11:28 AM
mopar dave
Mt Morris Michigan
most of it is posted above,heads flow [Email]325@.700[/Email], cam is a 106 lda [Email]installes@100.5[/Email], 950 bigs/1.400 venture=850 main body
[Re: mopar dave]
#1501012
09/14/13 11:39 AM
09/14/13 11:39 AM
Guitar Jones
Some more rear gear might help the 60', I wouldn't use a smaller carb, you may be able to use a 1050 Dominator on that combo. I have more compression (12.3) than you and my cam is 276/284 duration. About the same stall with 4.86 gears and a 32" tall tire. I'm using two 750's on a TR. I took the low gear out of the 904 and it still runs the same, just not as violent on the leave. My car is probably lighter than yours though at about 2780 with me in it.
[Re: mopar dave]
#1501013
09/14/13 11:40 AM
09/14/13 11:40 AM
Posts: 9,856 MI, usa
dvw
MI, usa
john calvert looked at my vid and says theirs no more tuning in the chassis as its doing what it should and no tire spin. he suggests issue is somewhere else, carb, convertor, rear gear, tranny gear.
You're in the same boat as me with a different combo. My 64 Belvedere runs 9.30/9.40@144/145 with mid 1.3 60s. No tire spin. In my case It could be carbs( 2 750 eddy) ,cam,converter,gear,. The bottom line for both of us is not enough low end torque to the tires. How do we improve? That is the million dollar question. I'm asking myself do I really want to give up a pretty quick great hooking combo with a relatively small (10.5) tires? I never thought I could run competitive local track prep bracket races with this type of car. I was wrong. My 2 cents Doug
[Re: mopar dave]
#1501014
09/14/13 11:44 AM
09/14/13 11:44 AM
B3422W5
Portage,michigan
60 foot is generally related to hook and torque to the ground. Based on your combo I would guess your car should 60 foot about 1.40-1.42 or so.... car makes good mph for the Et so its making good horsepower. my opinion may differ from some, but if that was my car I would suspect the convertor flashes too high. I would think 5000 flash would be closer to optimal. how/what rpm do you launch the car at? My w5 422 convertor flashed 5400 and I thought that was perfect. that was with a 273/280 roller and 13 to 1 compression. I would expect your torque peak to be somewhat lower than that. 5500 SHOULD be well past where that motor is making peak torque IMO. have you ever tried a 4 hole spacer on top of that indy intake? those intakes are huge, make good upper end horsepower, a 4 hole might generate more lower end torque. Gearing,etc seems like a non issue.
[Re: mopar dave]
#1501015
09/14/13 11:48 AM
09/14/13 11:48 AM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
Dave,
I just talked to Tim at Bullet and order the same lobes cut on a 108 and I'm putting it in at 104. 131 MPH for that weight of car I would think is pretty well close to optimized power wise
For your combo (especially the weight) I'm not sure I'd change very much other than maybe tire compound and pressure, with 5500 stall I'm not seeing how a smaller carb is gonna improve the 60' other than maybe tweaking the secondary cam shot.
What heads are you running? The Victor 340, I'm assuming it's ported and not holing back the heads and you are running a 2" spacer on it? The HVH tapered seems to work pretty well combined with plenum work, distribution is very good for what it is.
Cuda notches have great hook, I'd try upping tire pressure first to see if you can get it to spin, maybe try a smaller contact patch first.
[Re: Streetwize]
#1501017
09/14/13 11:57 AM
09/14/13 11:57 AM
B3422W5
Portage,michigan
Dave,
I think he is running an indy intake.....which is why I thought a 4 hole, or like you said a tapered spacer might make more torque
I think he said he is running an indy intake...hence the 4 hole, or like you said a tapered spacer might help.
[Re: B3422W5]
#1501018
09/14/13 12:11 PM
09/14/13 12:11 PM
Streetwize
Weddington, N.C.
Don, That's right, my bad I think Dave's got the Indy/Indybrock top end on it, I was thinking Vic for some reason....was out working in the yard early (beautiful fall day in Charlotte)...guess I had my coffee real late this morning
[Re: Streetwize]
#1501019
09/14/13 12:14 PM
09/14/13 12:14 PM
B3422W5
Portage,michigan
Don,
I think he has the " big" indy heads on it if they are flowing 320+....those are relatively " big" with a large intake plenum, and he doesn't have a lot of compression...I would think anything that makes things " smaller" will help 60 foot. Heck, it might even 60 foot better with mufflers on it
[Re: B3422W5]
#1501021
09/14/13 12:31 PM
09/14/13 12:31 PM
Streetwize
Weddington, N.C.
I agree, part of that is the cam being in early to trap more cylinder pressure. That is one of the best lobes UD/Bullet has, asymmetrical with an agressive opening and slower closing ramp, 183 @ .200 lift. With more cr I would agree the combo wouldn't want or need as much stall, I think the soft 60' is the trade-off of the cr/head flow mismatch but you sure cant argue with the awesome results all thing considered John calverts super stock mustang is a very highly scienced-out race car, not really an apples to apples regarding the very tricked out induction system, camshaft and exhaust, the hp and performance are the result of years and years of tweaking that car/class/combo and chassis going back to the early 70's, and with a few allowances (to enhance ET's for increasing class parity over the decades) along the way. It is an awesome car to behold. In this day of back halved purpose built FWD conversion cars being legal in SS it's amazing the 40+ yr old cars can still compete at all, but I'm really glad they still can
[Re: mopar dave]
#1501023
09/14/13 02:57 PM
09/14/13 02:57 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
408 small block. 60 is a consistant 1.51.
do you have a 700hp Small Block? what's the et and mph? whoops et and mph were in the Op... Yeah I'd think at that et you'd be in the low 1.40's. still good numbers.
[Re: mopar dave]
#1501026
09/14/13 06:36 PM
09/14/13 06:36 PM
Quicktree
yeah,but its about 5 yrs old now. not quite up to date. jesse a good carb man and he suggested his 950 stage 5+ which is a 850. plugs show it could use alittle more timing reading the ground strap. the color change is just about to the bend,so maybe a degree or 2? i'm at 36* now. 38* sounds like too much for a 11.3:1 408 on pump gas though?
ummm ground strap is plug heat range
http://www.youtube.com/watch?v=fiMM2S0aADM
[Re: mopar dave]
#1501029
09/14/13 07:41 PM
09/14/13 07:41 PM
Quicktree
yes,i watched that video last week and read on ngk site heat range was read on ground strap. so I called ngk and talked to one of their techs and he tells me timing is read off the ground strap. so,go figure.
ok so who you trust Larry Meaux one of the best head porters engine guru's or the NGK tech that probably has never raced or messed with a car.
[Re: Thumperdart]
#1501031
09/14/13 07:59 PM
09/14/13 07:59 PM
Quicktree
Exactly..........too many opinions on this according 2 who you talk 2.............
true but can you explain how timing can affect the strap?
[Re: mopar dave]
#1501033
09/14/13 08:21 PM
09/14/13 08:21 PM
Quicktree
I hear it both ways all the time,but lately more an indicator of timing. I was under the impression the more timing the more heat.
timing doesn't control the spark, just when it happens.
[Re: Quicktree]
#1501034
09/14/13 08:25 PM
09/14/13 08:25 PM
Posts: 814 in front of the computer
80arrow
I can't explain how it does but when I advance the timing in my car it moves the discoloration on the strap further towards the end of the strap. Some of the guys I talk to with forced induction say that you want the discoloration at the bend of the strap. Might be two different things but that's what happened with my car
[Re: 80arrow]
#1501035
09/14/13 08:27 PM
09/14/13 08:27 PM
Quicktree
yea boost is a whole different story.
[Re: mopar dave]
#1501039
09/14/13 10:01 PM
09/14/13 10:01 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
i'll have to contact a carb shop to see what it takes in a smaller carb. jesse bigs setup my 950 and I thought it was working quite well in my 408 with 11.4 comp, indy heads and intake,260/269-700 lift cam, 1 7/8 headers, 5500 8" stall, 727, 4.10, 28" tire. 67 cuda weights 3300 with me and my 60 is a 1.51. best [Email]10.39@131[/Email]
Dave my 416 Dart @ 3200 lbs w/4.56 & 29" tires w/caltrks. Ran a best 60' of 1.47. Usually 1.48-1.50 @ 125mph. I had ported W2's and the cam was 265@.050 590 lift installed @108. TA 4400 converter hat flashes 5400. Carb is a stock PF 950HP. Your running about where I would expect with that combo. JMO
[Re: rt66jim]
#1501042
09/15/13 12:09 AM
09/15/13 12:09 AM
mopar dave
Mt Morris Michigan
I should be at a 1.44 in relation to my best 10.39@131. so,what do you think needs attention, vert, rear gear or trans gear or is the car just too damn heavy?
[Re: mopar dave]
#1501043
09/15/13 12:41 AM
09/15/13 12:41 AM
B3422W5
Portage,michigan
Car isn't to heavy to not 60 foot better. I went 1.43 on leafs running Eddie heads and a flat tappet when it weighed 3450 and ran 10.70's. Just didn't have enough steam past 1100 feet or so. That combo was 11.8 compression. You have about a tenth in 60 foot that is possible to be picked up, IMO.
[Re: mopar dave]
#1501045
09/15/13 09:38 AM
09/15/13 09:38 AM
BradH
I should be at a 1.44 in relation to my best [Email]10.39@131.[/Email] so,what do you think needs attention, vert, rear gear or trans gear or is the car just too damn heavy?
I know it's an apples-to-oranges comparison, but my 440 Challenger @ 3750#s pulls 1.45-1.46 60s on 275R6015 DOT drag radials w/ 4.10s and a 4500-stall 'vert.
I'm not sure if you're under-geared for your torque curve or the converter hits "soft" or ???, but I'd expect you should be able to pull better 60s than my street/strip ride. You've got 5 MPH on top end over mine, yet mine has run solidly in the 10.5s w/ that much less MPH.
Simply trying to offer more food for thought...
