Re: 318 TO POLLY TRANSMISSION
[Re: mosweethemi]
#1500377
09/12/13 12:57 AM
09/12/13 12:57 AM
Posts: 172 IL,USA
bdusted440
IL,USA
Don't think so. I think it is the same as a 383 or 361 and such but maybe some more learnid members will chime in.
currently own 1976 duster deluxe 1974 gold duster 1993 Dakota sport 2000 caravan 2002 Durango 1970 v code superbee
[Re: bdusted440]
#1500378
09/12/13 07:50 AM
09/12/13 07:50 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Yes they swap.Did it on the 66 Charger my kid had.The poly is the wide block SB.Only difference is one bolt for trans wont match.Not a problem though.You will need the poly mounts and the exhaust etc from the LA.We used headers when we did his.Rocky
Chrysler Firepower
Re: 318 TO POLY TRANSMISSION
[Re: Andrewh]
#1500380
09/12/13 12:28 PM
09/12/13 12:28 PM
dogdays
I am doing this the other way, I have the '86 engine bolted to the '64 bellhousing. There IS one bolt that is different, and it's in a pretty important place, so I drilled.
The bolt in question is the lowest on the driver's side. It is right below the dowel pin. You should be able to drill through the hole in the block, through the transmission bellhousing. I'd suggest using a bolt and nut.
Using a modern engine mount system, where the engine is supported on each side and the transmission supported at the rear, this bolt (and the one on the passenger's side) is the most important one to keep the block and bellhousing together at the dowel. Using this mount system, one could leave out all the other bolts except the bottom two (one on each side)because the top of the transmission is pushing against the block. The bottom two are doing most of the work.
R.
PS: The LA is a direct descendant of the A Poly motor, has NOTHING to do with the B.
