leaking oil help/question #149994
11/13/08 01:57 AM
11/13/08 01:57 AM
ca, slo.
P
paulyvault Offline OP
P
ca, slo.
on a 69 charger 383 my oil pan gasket has got to be cracked or just reallllly old. i leak oil out the front drips each day where its parked, es no bueno. before i got in over my head i was wondering if putting a new gasket was easy or will i have a big prob, will i have to jack up the engine to really get at it and do it? thanks
paul
Re: leaking oil help/question [Re: paulyvault] #149995
11/13/08 09:01 AM
11/13/08 09:01 AM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
You should be able to knock the steering center link loose and get to it in the car pretty easy. With the steering linkage out of the way its pretty wide open.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
