Re: HELP!!!! 2002 Grand Caravan
[Re: 10sec440]
#149991
11/13/08 07:55 AM
11/13/08 07:55 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
Could be a vacuum leak in your plenum gasket as well.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: Jacob Pitt]
#149992
11/13/08 10:07 AM
11/13/08 10:07 AM
Posts: 1,758 KS
68SportSatvert
KS
Thanks guys!!! I just replaced the fuel filter when I did the other work. A couple other pieces of info - the van is sucking down gas like no tomorrow. I'll check the plenum gasket and see if I can get my hands on a fuel pressure tester. On the intake plenum, is this the same as the intake manifold? I believe that may be two pieces. Is it the gasket that goes between the top and bottom? One other thing is you can smell the unburned gas, if that makes sense. It doesn't smell like fuel but has a very distinct smell. My son has a 91 Cougar and I'm working on it due to what I believe is plugged cats. It smells the same way. Thanks again!!
