aftermarket floor shifter
#1499268
09/09/13 06:59 PM
09/09/13 06:59 PM
Posts: 4,990 new jersey usa
11secdart
new jersey usa
I`m thinking of putting a floor shifter in my D150 as I bracket race it on occasion and the column shifter just isn`t cutting it. Anybody install one? recommend a brand, will it fit a 518 o/d trans? Thanks
Re: aftermarket floor shifter
[Re: 340SHORTY]
#1499270
09/09/13 09:15 PM
09/09/13 09:15 PM
11secdart
new jersey usa
Thanks shorty I saw the B&M mega shifter for trucks but wasn`t sure if it would work with a 518
[Re: 11secdart]
#1499271
09/09/13 10:11 PM
09/09/13 10:11 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Iv had 2 Mega Shifters, 1 in my Duster race car and the other in a 88 D100 that I converted from a NP 435 4 speed to a 727.. Make sure you follow the instalation/adjusting procedures.
I am truckless..
[Re: 340SHORTY]
#1499272
09/09/13 10:45 PM
09/09/13 10:45 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Correct me if I'm wrong. But why wouldn't and shifter that fits a 727 work on a 518? There is no OD selection on the factory shifter or detent for OD on the valve body. That is electronically controlled. So a standard 727 PRND2L pattern is what your working with. As far as brands I really like the Hurst 1/4 stick for a no nonsense easy to use shifter.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: Azzkikrcuda]
#1499274
09/10/13 09:18 PM
09/10/13 09:18 PM
11secdart
new jersey usa
Thanks for the responses, I have another question if i go to a floor shifter , what do i do about the factory shifter being in park to turn the ignition on?
[Re: 11secdart]
#1499276
09/11/13 09:31 AM
09/11/13 09:31 AM
Posts: 15,487 Florida
scratchnfotraction
i bought a brand new hurst pro-matic for 200$.. biggest piece of crap I have ever bought with the hurst name on it. I took a beating around here on this board by all the others say it was just my dunb azz not adjusting it right...installed it wrong..I should not blame the shifter I should blame myself for not adjusting it right... well, the cable from day one before it ever was fired up,(some saying the shifter will act as a ground and ruin the cable which I know is trure) has a 1/4" slop back and forth with out ever moving the lever on the shifter. I can move it by hand unhooked from shifter that much before the trans lever ever moves. never have got that thing adjusted right, I can either get it to up shift correct and NOT down shaft correct or get it to down shift correct but not up shift correct. have to double shift it most time to get it in gear,handle pulls daown past the detents in gate like it is a for a 4 speed auto which it is not...maybe CAN be used for one I dont know. it does have a nice long handle as it is for the dodge trucks. tried a used cable same thing, tried a new cable same thing... I am going back to colum shift and adding a 5 speed in the other truck. hurst shifters not me. IMHO, dont get the hurst pro-matic truck shifter. another memeber here got his the same time with same troubles so it is not just my dumb azz not adjusting it correctly.
[Re: scratchnfotraction]
#1499278
09/14/13 12:30 AM
09/14/13 12:30 AM
Posts: 1,739 Grand Forks, ND
Hemi_Ram
Grand Forks, ND
Yes what Mike said; tried adjusting it and you have to slam it into gear and then softly move it a bit to the next gear for it to operate correctly. The geometry is wrong on the supplied 727 lever; I need to get off my a## and complain to Hurst as all of the products I have used in the past have been great> Pass on the pro matic my friend.
[Re: Twostick]
#1499281
09/15/13 11:32 AM
09/15/13 11:32 AM
11secdart
new jersey usa
coronet, pm sent, Thanks, btw can I just leave the column shifter location in the park position with the linkage disconnected and the key switch will work normal and rely on the floor shifter for park and other gears.
