aftermarket floor shifter #1499268
09/09/13 06:59 PM
09/09/13 06:59 PM
new jersey usa
11secdart Offline OP
new jersey usa
I`m thinking of putting a floor shifter in my D150 as I bracket race it on occasion and the column shifter just isn`t cutting it. Anybody install one? recommend a brand, will it fit a 518 o/d trans? Thanks
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: aftermarket floor shifter [Re: 11secdart] #1499269
09/09/13 07:29 PM
09/09/13 07:29 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
B&M , Hurst, Art Carr, Winters make shifters that will work with the 518. How deep are your pockets is the question.. A few of them have longer handles that are best for a truck..
I am truckless..
Re: aftermarket floor shifter [Re: 340SHORTY] #1499270
09/09/13 09:15 PM
09/09/13 09:15 PM
new jersey usa
new jersey usa
Thanks shorty I saw the B&M mega shifter for trucks but wasn`t sure if it would work with a 518
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
Re: aftermarket floor shifter [Re: 11secdart] #1499271
09/09/13 10:11 PM
09/09/13 10:11 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Iv had 2 Mega Shifters, 1 in my Duster race car and the other in a 88 D100 that I converted from a NP 435 4 speed to a 727.. Make sure you follow the instalation/adjusting procedures.
I am truckless..
Re: aftermarket floor shifter [Re: 340SHORTY] #1499272
09/09/13 10:45 PM
09/09/13 10:45 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Correct me if I'm wrong. But why wouldn't and shifter that fits a 727 work on a 518?
There is no OD selection on the factory shifter or detent for OD on the valve body. That is electronically controlled.
So a standard 727 PRND2L pattern is what your working with.
As far as brands I really like the Hurst 1/4 stick for a no nonsense easy to use shifter.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: aftermarket floor shifter [Re: 11secdart] #1499273
09/09/13 11:26 PM
09/09/13 11:26 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I had a B&M Quicksilver in my 79 dodge with a 518 trans and it worked great.
Re: aftermarket floor shifter [Re: Azzkikrcuda] #1499274
09/10/13 09:18 PM
09/10/13 09:18 PM
new jersey usa
new jersey usa
Thanks for the responses, I have another question if i go to a floor shifter , what do i do about the factory shifter being in park to turn the ignition on?
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
Re: aftermarket floor shifter [Re: 11secdart] #1499275
09/10/13 10:26 PM
09/10/13 10:26 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Leave the Column be. Or swap to a stick column
Re: aftermarket floor shifter [Re: 11secdart] #1499276
09/11/13 09:31 AM
09/11/13 09:31 AM
scratchnfotraction Offline
i bought a brand new hurst pro-matic for 200$.. biggest piece of crap I have ever bought with the hurst name on it.
I took a beating around here on this board by all the others say it was just my dunb azz not adjusting it right...installed it wrong..I should not blame the shifter I should blame myself for not adjusting it right...
well, the cable from day one before it ever was fired up,(some saying the shifter will act as a ground and ruin the cable which I know is trure) has a 1/4" slop back and forth with out ever moving the lever on the shifter. I can move it by hand unhooked from shifter that much before the trans lever ever moves.
never have got that thing adjusted right, I can either get it to up shift correct and NOT down shaft correct or get it to down shift correct but not up shift correct.
have to double shift it most time to get it in gear,handle pulls daown past the detents in gate like it is a for a 4 speed auto which it is not...maybe CAN be used for one I dont know.
it does have a nice long handle as it is for the dodge trucks.
tried a used cable same thing, tried a new cable same thing...
I am going back to colum shift and adding a 5 speed in the other truck.
hurst shifters not me.
IMHO, dont get the hurst pro-matic truck shifter.
another memeber here got his the same time with same troubles so it is not just my dumb azz not adjusting it correctly.
Re: aftermarket floor shifter [Re: scratchnfotraction] #1499277
09/13/13 11:32 PM
09/13/13 11:32 PM
Clinton Twp. Michigan
coronet1966d Offline
I have a B&M truck megashifter that I only had installed for a few months. driven twice, im going back to a stick PM me if interested
Re: aftermarket floor shifter [Re: scratchnfotraction] #1499278
09/14/13 12:30 AM
09/14/13 12:30 AM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
Yes what Mike said; tried adjusting it and you have to slam it into gear and then softly move it a bit to the next gear for it to operate correctly. The geometry is wrong on the supplied 727 lever; I need to get off my a## and complain to Hurst as all of the products I have used in the past have been great> Pass on the pro matic my friend.
Re: aftermarket floor shifter [Re: 11secdart] #1499279
09/14/13 01:19 AM
09/14/13 01:19 AM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
The neutral safety switch is in the transmission and not in the column, it should work with the ignition no matter what shifter you hook up
Re: aftermarket floor shifter [Re: CTD5.9] #1499280
09/14/13 01:09 PM
09/14/13 01:09 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
I think he was referring to the ign switch itself. Can't get the keys out of the switch unless the column is in the Park/Locked position.
Kevin
Re: aftermarket floor shifter [Re: Twostick] #1499281
09/15/13 11:32 AM
09/15/13 11:32 AM
new jersey usa
new jersey usa
coronet, pm sent, Thanks, btw can I just leave the column shifter location in the park position with the linkage disconnected and the key switch will work normal and rely on the floor shifter for park and other gears.
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
