Re: 37 Plymouth PU Ressurection.
[Re: AZ_A12_BEE]
#1499153
12/29/13 03:54 PM
12/29/13 03:54 PM
Posts: 2 California
38PlyPickupGuy
California
Hey AZ, Nice 37. I have a 38 that in mostly original shape. I'd be interested in some of the original parts. If you still have them. Do you have the original fuel tank? It looks like this: I'm looking for one. Thanks
[Re: elitecustombody]
#1499158
05/30/14 01:15 AM
05/30/14 01:15 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
My truck inop till I pull the motor and trans and reseal them. It looks like the Exxon Valdez ran aground under the truck.
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: AZ_A12_BEE]
#1499159
08/30/14 09:11 PM
08/30/14 09:11 PM
AZ_A12_BEE
Dreaming of the 808
Motor and trans are pulled to get cleaned up and resealed
37 Plymouth PU
[Re: AZ_A12_BEE]
#1499160
08/30/14 09:12 PM
08/30/14 09:12 PM
AZ_A12_BEE
Dreaming of the 808
Removed the wood floor board and I will make a new one out of metal
37 Plymouth PU
[Re: AZ_A12_BEE]
#1499161
08/31/14 10:38 PM
08/31/14 10:38 PM
AZ_A12_BEE
Dreaming of the 808
While the motor is out I'm fixing some issue. Going to install a Gen 2 internally regulator Ford alternator and clean up this crappy wiring.
37 Plymouth PU
[Re: AZ_A12_BEE]
#1499162
08/31/14 10:41 PM
08/31/14 10:41 PM
AZ_A12_BEE
Dreaming of the 808
Removed the toe board. I will get it sand blasted and weld all the extra holes closed. The lack of rust in this truck is amazing.
Toe board
37 Plymouth PU
[Re: AZ_A12_BEE]
#1499166
08/31/14 10:45 PM
08/31/14 10:45 PM
AZ_A12_BEE
Dreaming of the 808
Paper glove box is still intact and has no holes in it
37 Plymouth PU
[Re: AZ_A12_BEE]
#1499167
09/01/14 03:34 PM
09/01/14 03:34 PM
AZ_A12_BEE
Dreaming of the 808
Removed all the under hood wiring and I will eliminate what I can and replace the rest
37 Plymouth PU
[Re: AZ_A12_BEE]
#1499168
09/01/14 03:57 PM
09/01/14 03:57 PM
AZ_A12_BEE
Dreaming of the 808
I removed the glove box liner, hard to believe it was still intact after 77 years
37 Plymouth PU
