Page 4 of 13 1 2 3 4 5 6 12 13
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499070
09/26/13 05:13 PM
09/26/13 05:13 PM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
Got the rear end back together, just need shocks and weld the spring perches to the axle tube which I will do when I weld a bracket in to support the front of the fuel tank
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499071
09/26/13 05:15 PM
09/26/13 05:15 PM
Dreaming of the 808
Dreaming of the 808
Another pic of axle and springs
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499072
09/26/13 05:54 PM
09/26/13 05:54 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Excellent Dave!
Hows the ride height?
Re: 37 Plymouth PU Ressurection. [Re: nomore65BelvJim] #1499073
09/26/13 07:02 PM
09/26/13 07:02 PM
Dreaming of the 808
Dreaming of the 808
Excellent Dave!
Jim, it's perfect after I had the new springs de-arched 3 inches, driveshaft is a straight shot to the tranny now.
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499074
09/26/13 11:48 PM
09/26/13 11:48 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Excellent Dave!
Its best to have a few degrees of drive shaft angles, in opposite directions, or the u-joints will lock up from not moving.
Gene
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499075
09/27/13 10:35 PM
09/27/13 10:35 PM
Excellent Dave!
Sweet! Your knocking off items on the "before I can safely drive it list" in record fashion. You've got to be jazzed
Re: 37 Plymouth PU Ressurection. [Re: nomore65BelvJim] #1499076
09/28/13 12:15 PM
09/28/13 12:15 PM
Dreaming of the 808
Dreaming of the 808
Excellent Dave!
Today I'm mounting the fuel tank and welding the spring perches, new carb should be here today too, I'm thinking 2 weeks and its on the road
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499077
09/29/13 08:07 PM
09/29/13 08:07 PM
Dreaming of the 808
Dreaming of the 808
Tail lights/license plate brackets arrive, very nice product
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499078
09/30/13 01:35 PM
09/30/13 01:35 PM
Uh oh, looks like its time for the Vega taillights to say goodbye
Those will look sweet, very "period correct"
Re: 37 Plymouth PU Ressurection. [Re: nomore65BelvJim] #1499079
09/30/13 03:01 PM
09/30/13 03:01 PM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
Lookin great, Dave!
Re: 37 Plymouth PU Ressurection. [Re: Hotwheelsjr] #1499080
09/30/13 10:43 PM
09/30/13 10:43 PM
Dreaming of the 808
Dreaming of the 808
The front brakes were a mess. Getting the brakes fixed, had 2 new hoses made today and a local company is re-shoeing the front brake shoes. I got 2 new wheel cylinders and front inner seals coming from back east.
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499081
10/01/13 12:23 AM
10/01/13 12:23 AM
Hotwheelsjr Offline
Hotwheelsjr  Offline
I have to work on mine either tonight or tomorrow morning. Weather is finally BEAUTIFUL at night and early morning!
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499082
10/02/13 09:19 PM
10/02/13 09:19 PM
NH
3
36dodge Offline
36dodge  Offline
NH
I may need a gas tank as well for my 37
Re: 37 Plymouth PU Ressurection. [Re: 36dodge] #1499083
10/02/13 10:58 PM
10/02/13 10:58 PM
Dreaming of the 808
Dreaming of the 808
New gas tank off of eBay arrived today, $107.00 shipped to my door, it's 11 gallons out of a mid 90s Suzuki Sidekick, fits perfect behind the rear axle. Since the tank is now behind the axle I got a fuel door off of a 1996 Buick Riviera which I will mount and weld into the drivers side rear fender
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499084
10/02/13 11:03 PM
10/02/13 11:03 PM
Dreaming of the 808
Dreaming of the 808
Front brake shoe relined, waiting on inner seals and new wheel cylinders to be delivered
Re: 37 Plymouth PU Ressurection. [Re: 36dodge] #1499085
10/02/13 11:05 PM
10/02/13 11:05 PM
Dreaming of the 808
Dreaming of the 808
37 pickup?
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499086
10/03/13 07:29 AM
10/03/13 07:29 AM
AZ
Mike P Offline
Mike P  Offline
AZ
Are you going to leave the original pipe and gas cap on the cab or weld the hole closed?
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: 37 Plymouth PU Ressurection. [Re: Mike P] #1499087
10/03/13 11:39 AM
10/03/13 11:39 AM
Dreaming of the 808
Dreaming of the 808
Mike, pipe and tank are long gone and the hole in cab is covered with this old Pontiac emblem, it will get welded closed during restoration in a couple of years
The hole in the floor of the cab will get a metal plate siliconed over it till I weld it shut during the restoration in a couple of years.
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499088
10/03/13 11:57 PM
10/03/13 11:57 PM
Dreaming of the 808
Dreaming of the 808
Box full of brake parts arrived today, now I can get the front axle back together
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499089
10/03/13 11:58 PM
10/03/13 11:58 PM
Dreaming of the 808
Dreaming of the 808
Fuel door is trimmed and ready for install
