Shrinking Sheet metal !! Heat/ice or shrink hamer #14972
03/11/05 02:42 PM
03/11/05 02:42 PM
Cornfield. IN
Clair Offline OP
Pot Stirrer #4
Clair  Offline OP
Pot Stirrer #4
Cornfield. IN
Anybody use a shrinking hammer or heat and ice to pull some stretched metal back.
Have a fender that took a pretty good hit and have it looking pretty good but still have some high spots/stretched metal.
Is the $40 shrinking hammer worth the money.
Has anybody used heat and water/ice?
Anybody try these methods and what was the outcome
Thanks Clair.
Edit I use to just mud it in but would too really try for the best panel this time
Re: Shrinking Sheet metal !! Heat/ice or shrink ha [Re: Clair] #14973
03/11/05 03:07 PM
03/11/05 03:07 PM
The shrinking hammer will work to a certain degree. It depends on how "high" your problem area is. I sometimes use the torch and a rag soaked in ice water to pull them back. You start on the outside edge of the high spot and work your way in. I also have a heating/shrinking tip for my stud gun. It works wonders on the little ones, then finish with a body file. If the area is radically distorted and appears as a "bubble" from too much hammer work, I sometimes remove some material by slicing it in the middle with a thin cutting wheel, hammer and dolly it flat, then weld the split back. I realy hate using filler and sometimes go overboard to avoid using it. Hope this helps.
Re: Shrinking Sheet metal !! Heat/ice or shrink hamer [Re: Clair] #14974
03/11/05 03:08 PM
03/11/05 03:08 PM
Seattle WA
RichV Offline
RichV  Offline
Seattle WA
I think heat is the best method for shrinking. I haven't had much luck with a shrinking hammer.
Re: Shrinking Sheet metal !! Heat/ice or shrink hamer [Re: Clair] #14975
03/11/05 03:10 PM
03/11/05 03:10 PM
Shrink hammer worked better for me. Ice only worked on the hail dents, but I'm not a bodyman.
Re: Shrinking Sheet metal !! Heat/ice or shrink ha [Re: Clair] #14976
03/11/05 03:18 PM
03/11/05 03:18 PM
Also, one of these will make an average man into a metalworking genius on the small dents.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=43996&item=4534622885&rd=1
Re: Shrinking Sheet metal !! Heat/ice or shrink hamer [Re: Clair] #14977
03/11/05 03:38 PM
03/11/05 03:38 PM
Cornfield. IN
Clair Offline OP
Pot Stirrer #4
Clair  Offline OP
Pot Stirrer #4
Cornfield. IN
Good info muddshark
Do you have that tool ???
I slit/reweld the one dent/ to stop it from OIL canning.
That worked well.
The area I am currently working is not that bad will try the heat/ice and see how that does.
Yes I basicly over streached it from beeting it out.
Re: Shrinking Sheet metal !! Heat/ice or shrink ha #14978
03/11/05 03:46 PM
03/11/05 03:46 PM
Under the big sky
stateline Online content
stateline  Online Content
Under the big sky
A stud gun with a shrinking tip works real well for the average guy . You can use an air hose instead of water to shrink with too.
Re: Shrinking Sheet metal !! Heat/ice or shrink ha [Re: stateline] #14979
03/11/05 03:51 PM
03/11/05 03:51 PM
Cornfield. IN
Clair Offline OP
Pot Stirrer #4
Clair  Offline OP
Pot Stirrer #4
Cornfield. IN
I was not aware they made a shrinking tool for stud guns
What’s a good gun that will last/work well?
I have alway wanted 1 and now may be the time !!!!
Re: Shrinking Sheet metal !! Heat/ice or shrink ha [Re: Clair] #14980
03/11/05 04:05 PM
03/11/05 04:05 PM
I've got a Uni-spotter 4500. I've had it for years and have abused it, dropped it and it's still cookin'. I also have a couple of bullseye picks in different sizes. Fix one fender with one and you'll wonder how you ever lived without one. Same for the stud gun.
Re: Shrinking Sheet metal !! Heat/ice or shrink hamer *DELETED* [Re: Clair] #14981
03/14/05 05:50 PM
03/14/05 05:50 PM
Cornfield. IN
Clair Offline OP
Pot Stirrer #4
Clair  Offline OP
Pot Stirrer #4
Cornfield. IN
Post deleted by Clair
