Drill the thermostat or not? #1497354
09/06/13 08:03 PM
09/06/13 08:03 PM
Minnesota
Mad Accountant Offline OP
Minnesota
Installing a new thermostat, and wondering if i should drill a small hole in it or not. If so, why and how big? If not, why not? Go!
Re: Drill the thermostat or not? [Re: Mad Accountant] #1497355
09/06/13 08:08 PM
09/06/13 08:08 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
A small hole about 1/16 will aid in removing any air pockets..
I am truckless..
Re: Drill the thermostat or not? [Re: 340SHORTY] #1497356
09/06/13 08:18 PM
09/06/13 08:18 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Most new stats have a air relief already.
Re: Drill the thermostat or not? [Re: stumpy] #1497357
09/06/13 08:21 PM
09/06/13 08:21 PM
Groveland, MA
SteveS Offline
SteveS  Offline
Groveland, MA
Correct.
Very few do not.
Steve
Someday I'll have another C-body.
Re: Drill the thermostat or not? [Re: SteveS] #1497358
09/06/13 11:14 PM
09/06/13 11:14 PM
michigan woods
imfixinmopars426 Offline
michigan woods
yes...1/16-1/8" will help greatly for filling!
Re: Drill the thermostat or not? [Re: Mad Accountant] #1497359
09/06/13 11:20 PM
09/06/13 11:20 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I drilled an 1/8" hole in mine. No more need to burp the system on fill up.
Re: Drill the thermostat or not? [Re: SteveS] #1497360
09/07/13 05:04 PM
09/07/13 05:04 PM
Minnesota
Minnesota
How do you tell if the tstat has an air relief? There is no visible hole, and i can't force air through it at least by mouth.
Re: Drill the thermostat or not? [Re: Mad Accountant] #1497361
09/07/13 05:14 PM
09/07/13 05:14 PM
Grand Prairie,Texas
Grand Prairie,Texas
If there is no hole then it doesn't have a relief.
Re: Drill the thermostat or not? [Re: Mad Accountant] #1497362
09/07/13 05:32 PM
09/07/13 05:32 PM
Groveland, MA
SteveS Offline
SteveS  Offline
Groveland, MA
What thermostat is it? Most are vented via a not very obvious notch in the valve.
Steve
Re: Drill the thermostat or not? [Re: SteveS] #1497363
09/07/13 05:51 PM
09/07/13 05:51 PM
BDW Offline
BDW  Offline
Any harm in drilling a 1/8" hole if it already has one?
Re: Drill the thermostat or not? [Re: Mad Accountant] #1497364
09/07/13 07:26 PM
09/07/13 07:26 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Some info from the Stant website;
"Many thermostats have a “jiggle pin” or “check valve” that allows trapped air in the cooling system to pass through the thermostat and be released from the system.
If a Stant thermostat does not have a jiggle pin, it will have a "bleed notch” or other method of removing air from the system."
http://www.stant.com/consumer-products/abcs-of-thermostats
Re: Drill the thermostat or not? [Re: moparfan53] #1497365
09/08/13 12:29 AM
09/08/13 12:29 AM
Groveland, MA
SteveS Offline
SteveS  Offline
Groveland, MA
FYI- I spent a few years as product engineering manager for Stant's thermostat group.
Steve
Re: Drill the thermostat or not? [Re: Mad Accountant] #1497366
09/08/13 12:54 AM
09/08/13 12:54 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Yup, drill a hole...I thin I tossed a 1/8" into mine...regardless of how much water is lets pass through..nothing beats knowing that all the air has been expelled!
Re: Drill the thermostat or not? [Re: Mad Accountant] #1497367
09/08/13 03:02 AM
09/08/13 03:02 AM
I drill two or three 1/8 inch holes across from each other in all of the new ones, old motorhome style, thermostasts I use
Re: Drill the thermostat or not? [Re: SteveS] #1497368
09/08/13 07:43 AM
09/08/13 07:43 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Would you remember any thermostats with set points above 205 degrees F ?
210, 214 or even 220 degrees F maybe?
a few years ago i searched through the Stant paper catalog looking for high temperature thermostats and found the
Stant Standard Grade #13352 rated 205 F
and installed this in a
1995 Magnum 360 V8.
This Stant crosses to a
CarQuest #30210
205 degrees F
Re: Drill the thermostat or not? [Re: 360view] #1497369
09/08/13 09:44 AM
09/08/13 09:44 AM
ill
dennismopar73 Offline
ill
My race motors I just run a spacer to just restrict the flow, in my street stuff I drill a 1/4 hole
I alwas buy the safe stats that way if thego bad they stick wide open, not closed !
Re: Drill the thermostat or not? [Re: Mad Accountant] #1497370
09/08/13 10:07 AM
09/08/13 10:07 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I'm having a heck of a time imagining that.
Don't be the exception.
Re: Drill the thermostat or not? [Re: 360view] #1497371
09/08/13 06:48 PM
09/08/13 06:48 PM
Groveland, MA
SteveS Offline
SteveS  Offline
Groveland, MA
1995 Magnum 360 V8.
CarQuest #30210
205 degrees F
That's the only "mainstream" one. Ten years ago I could have made something for you!
Steve
Re: Drill the thermostat or not? [Re: BDW] #1497372
09/12/13 01:24 PM
09/12/13 01:24 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
The difference between a drilled hole and a one have valve is no flow during warm up.
That is why out of the box thermostats do not have a hole.
It may be more of a chore to rid of air after the initial fill but after a couple cycles the air will find it's way to the radiator cap or coolant reservoir.
One vote here for faster warm up.
Re: Drill the thermostat or not? [Re: Magnum] #1497373
09/12/13 06:44 PM
09/12/13 06:44 PM
Groveland, MA
SteveS Offline
SteveS  Offline
Groveland, MA
If anyone is that nervous about an air pocket on initial fill, they can push the thermostat open and wedge an aspirin in the opening. The thermostat will stay open a little bit until the coolant dissolves it, or the thermostat opens and spits it out.
Steve
