Re: Drill the thermostat or not? [Re: Mad Accountant] #1497374
09/12/13 08:53 PM
09/12/13 08:53 PM
My vote, a 1/32" hole. Takes 1 minute to do. No effect on cooling. As said quicker/more complete initial fill. Time is money
Re: Drill the thermostat or not? [Re: RapidRobert] #1497375
09/12/13 10:58 PM
09/12/13 10:58 PM
Minnesota
Mad Accountant Offline OP
Minnesota
Drilled a 1/16" hole, filled it and ran it. Worked great without having to check it 12 times. Love the aspirin trick, sort of like the bread in the copper pipe at home. You learn something new every dang day!
Re: Drill the thermostat or not? [Re: Mad Accountant] #1497376
09/13/13 04:12 AM
09/13/13 04:12 AM
Yeah I liked that too now what is the bread in the copper pipe trick
Re: Drill the thermostat or not? [Re: RapidRobert] #1497377
09/13/13 05:04 AM
09/13/13 05:04 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
If you're sweating together copper pipes and there is a little water trickle, you can shove bread in the pipe to hold back/suck up the water long enough to get the pipes soldered together.
The bread will dissolve when you turn the water back on.
I can't afford this. mark
Re: Drill the thermostat or not? [Re: a12superbee] #1497378
09/13/13 05:10 AM
09/13/13 05:10 AM
alright
