Is this the right power steering pump? 70 318 Barracuda #1496943
09/06/13 08:28 AM
09/06/13 08:28 AM
Boston, MA
crocha617 Offline OP
Boston, MA
Swapped out the power pump for one I had on my shelf and its about a 1/4" out of alignment. Is this a big block bracket setup or something. The one I took off was out of line a little also. Help!!!
Re: Is this the right power steering pump? 70 318 Barracuda [Re: crocha617] #1496944
09/06/13 08:36 AM
09/06/13 08:36 AM
Boston, MA
Boston, MA
Another...
Re: Is this the right power steering pump? 70 318 Barracuda [Re: crocha617] #1496945
09/06/13 11:54 AM
09/06/13 11:54 AM
North Carolina
469runner Offline
469runner  Offline
North Carolina
That is the right one. Not uncommon for a slight misalignment of pulleys, just shim it some if it is a problem.
Re: Is this the right power steering pump? 70 318 Barracuda [Re: crocha617] #1496946
09/06/13 02:01 PM
09/06/13 02:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Can't see the misalignment. What is that part BEHIND the main front bracket ? will the pulleys line up with that out of there ?
