D100 or D150? #1495516
09/03/13 02:03 PM
09/03/13 02:03 PM
Goodyear Arizona
midnite360 Offline OP
Goodyear Arizona
Hello, I was always under the impression that my 1977 Stepside was a D150, It is badged as one and it is a heavy duty half-ton and doesn't require cats. I have the original build sheet and it says D100. I am curious if D150's were just different badges or actually a different model then the D100's. Thanks!
Re: D100 or D150? [Re: midnite360] #1495517
09/03/13 02:12 PM
09/03/13 02:12 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
The GVWs were higher so they could avoid all the polution equipment. The standard spring ratings were higher on the D150s but D100s could be ordered with the higher rated springs as well.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: D100 or D150? [Re: midnite360] #1495518
09/03/13 02:13 PM
09/03/13 02:13 PM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
D150's did not come along until mid year 77. The designation was primarly used for heavier gross vehicle rating...hence less emissions components.
They did get different badges. The rating for th 150's should be over 6000 GVWR...and is considered Heavy Duty Emissions...thru 1978 for federal.
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: D100 or D150? [Re: Soopernaut] #1495519
09/03/13 02:15 PM
09/03/13 02:15 PM
Goodyear Arizona
Goodyear Arizona
Interesting stuff! Previous owner said it was a warlock, Had the stripes around the dash and on the doors still, But I am thinking the dealership might have just added the warlock pinstriping to an already highly optioned truck to get it out the door as the Warlock Code Is not on the Build Sheet. I am going to have to slap some D100 badges on it.
Re: D100 or D150? [Re: dynotune440] #1495520
09/03/13 02:16 PM
09/03/13 02:16 PM
Goodyear Arizona
Goodyear Arizona
OK so it is entirely possible for a 1977 that is a D100 with a weight over 6000 to be badged D150?
Re: D100 or D150? [Re: midnite360] #1495521
09/03/13 02:17 PM
09/03/13 02:17 PM
dynotune440 Offline
dynotune440  Offline
yes
Re: D100 or D150? [Re: dynotune440] #1495522
09/03/13 02:19 PM
09/03/13 02:19 PM
Goodyear Arizona
Goodyear Arizona
Thank you.
Re: D100 or D150? [Re: midnite360] #1495523
09/03/13 02:39 PM
09/03/13 02:39 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Put it this way. Its just a badge. Halftons(100/150) have an axle roaring of 3300# Most 3/4tons(200/250)are the same. Some 3/4tons have the 4400# axle rating. You would think all 1tons(300/350) would be 4400# rating. Well I found out that is Not true. My crewcab needs rotors and I came across a kid parting a 350 on craigslist. The dam thing was Hilton suspension. 3300# rated axle for a "1ton" The dumbist thing ever.
Re: D100 or D150? [Re: 76dodgeboy] #1495524
09/03/13 02:47 PM
09/03/13 02:47 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
But it affects emissions and insurance it different states.
Re: D100 or D150? [Re: 76dodgeboy] #1495525
09/03/13 03:00 PM
09/03/13 03:00 PM
Goodyear Arizona
Goodyear Arizona
Yeah, I live in Arizona and I really enjoy sticking it to the man and not having to run cats!
Re: D100 or D150? [Re: midnite360] #1495526
09/03/13 03:34 PM
09/03/13 03:34 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I bought a 76 and a 78 new. In 76 it was a suspension option on a D100 and the truck came through with no emission controls. The 78 was badged as a D150 and it was the same package.
I tell you it was a great vehicle to buy in the mid 70's, the cars were full of emissions jeejaws and hoses and none of them did any good anyway. Pop the hood on a 150 and it was clean as a whistle under there.
Sheldon
Re: D100 or D150? [Re: RUNCHARGER] #1495527
09/03/13 03:43 PM
09/03/13 03:43 PM
Goodyear Arizona
Goodyear Arizona
Sheldon
Yeah it's great! If I remember correctly (its been awhile since my truck has ran) All they look for is a PCV valve.
Re: D100 or D150? [Re: 76dodgeboy] #1495528
09/03/13 04:57 PM
09/03/13 04:57 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
My '87 D100 was used by the first owner to pull a 5th wheel trailer. I never saw the trailer so I don't know how big a 5th wheel it was, but the evidence is still in the bed (holes for 5th wheel mount and a female electrical connector in the driver side inner bed wall). I have not counted the spring leaves, but it does ride stiff. Amazingly enough the power train is (for now) 318/2 barrel/727 and 8.25 axle!
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: D100 or D150? [Re: Polarapete] #1495529
09/04/13 12:27 PM
09/04/13 12:27 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
I have my '76. It's a D100 rated at 06100. Enough to keep the Cats of it. Smog gave me a bit of a fit, till they realized it was over 06000.
Re: D100 or D150? [Re: bigblock340power] #1495530
09/04/13 01:22 PM
09/04/13 01:22 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Im reffering to axle rating
Re: D100 or D150? [Re: 76dodgeboy] #1495531
09/04/13 04:38 PM
09/04/13 04:38 PM
Goodyear Arizona
Goodyear Arizona
I know but we also got into GVWR One time I went to emissions and they gave me a hard time because the Vin was only on the door and not on the core support because it broke off. "Im going to pass you, But you could have easily replaced the door with a different vin." Oh really? Like it is any harder to put a new core support on that has a different Data Plate?
Re: D100 or D150? [Re: midnite360] #1495532
09/04/13 07:46 PM
09/04/13 07:46 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Like Sam stated the 50's labeling came in mid 77.
I've found that Dodge had 2 axle ratings available on their trucks. My 73 W200 had a lite and a heavy duty axle. No W250 in 73. My 92 D350 came with a 3600lb front axle or the Cummins like mine has the 4000lb axle. No D300 in 92.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: D100 or D150? [Re: moparmarks] #1495533
09/04/13 07:53 PM
09/04/13 07:53 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
The D100/150 stuff is confusing. My 81 stepside is a D150, originally a /6. The 88 shorty I had was a D100 with a 318. My research showed that in 88 to get a 360 it had to be a D150...
I am truckless..
Re: D100 or D150? [Re: 340SHORTY] #1495534
09/04/13 07:56 PM
09/04/13 07:56 PM
moparmarks Offline
moparmarks  Offline
Ya they got a little weird there for a while before dropping the D100. Same with Ford. F100 was a 1/2T and the F150 was a 5/8T for a few years.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
