exhaust paint
#1493562
08/31/13 02:04 PM
08/31/13 02:04 PM
Posts: 1,487 STL
cdstl
STL
I am going to be finishing my exhaust soon and would like to paint it silver. What do you guys recommend? I would like to buy something off of the shelf.
thanks
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: exhaust paint
[Re: cdstl]
#1493566
08/31/13 11:38 PM
08/31/13 11:38 PM
Posts: 1,487 STL
cdstl
STL
Thanks. VHT was the way that I had been leaning for the collectors to the tailpipes.
Re: exhaust paint
[Re: cdstl]
#1493567
09/01/13 06:20 AM
09/01/13 06:20 AM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
Just a question. What kind of metal is your exhaust made of? Mine is all aluminized (both on my '76 pickup, and my '71 340 Duster), never rusts (best damn stuff for exhaust). But I did have to paint the stock manifolds (VHT baby!).
Re: exhaust paint
[Re: bigblock340power]
#1493568
09/01/13 08:09 AM
09/01/13 08:09 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Yup, I use aluminized pipes too. If you don't know, it's steel tubing that's coated in a thin layer of aluminum. the pipes do NOT rust.
however, if you weld your system together, the welds will rust. that's the only rust on my whole system, right at the welds.
**Photobucket sucks**
Re: exhaust paint
[Re: 70Cuda383]
#1493569
09/01/13 10:01 PM
09/01/13 10:01 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Just a question. What kind of metal is your exhaust made of? Mine is all aluminized (both on my '76 pickup, and my '71 340 Duster), never rusts (best damn stuff for exhaust). But I did have to paint the stock manifolds (VHT baby!). Yup, I use aluminized pipes too. If you don't know, it's steel tubing that's coated in a thin layer of aluminum. the pipes do NOT rust.
I've scuffed the aluminum coating with a scotchbrite pad then coated with Eastwood's exhaust system paint{even the mufflers}...Why ??? As stated the welds do rust but also because now I can go back and with a quick touch-up have the whole system look brand new...
I can't beleive how much crap flies up and scorches itself to the pipes sometimes...
