Dana 60 Howling? New gears. Could they be bad?
#1492290
08/29/13 10:53 AM
08/29/13 10:53 AM
Posts: 4,244 Canada
Kam*Kuda
Canada
Dana 60, Rear end. Detroit locker The rear end howls but the wear pattern is perfect. Could they be bad gears? I am pretty sure the rear end is from a Ford pickup. I see that there are gears for a dodge and a different set for a ford. Anyone know what the difference is? Page 21 http://www.motivegear.com/pdf/LD_DIFFCAT_011_1.pdfIt appears that For 3.54 it is the same dodge or ford but 3.55 is different? COuld this be part of the problem?
Re: Dana 60 Howling? New gears. Could they be bad?
[Re: challengermike]
#1492294
08/29/13 07:05 PM
08/29/13 07:05 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
True dana gears seem to be absolutely quiet when setup right. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1492295
08/29/13 09:04 PM
08/29/13 09:04 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
[Re: Kam*Kuda]
#1492299
08/30/13 01:56 AM
08/30/13 01:56 AM
Posts: 4,244 Canada
Kam*Kuda
Canada
Sorry for the confusion The gears I have are called Quality gears Not Motive
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: DoctorDiff]
#1492302
08/30/13 10:39 AM
08/30/13 10:39 AM
Posts: 4,244 Canada
Kam*Kuda
Canada
Any thoughts on why it is howling when the gear pattern looks good?
[Re: Kam*Kuda]
#1492303
08/30/13 10:49 AM
08/30/13 10:49 AM
Posts: 52,972 Romeo MI
MR_P_BODY
JMO... but I dont call that pattern good... it looks like the surface is irregular... the edges of the test area dont show a smooth line... it very well could be the gear set not ground smooth
#1492306
08/30/13 09:23 PM
08/30/13 09:23 PM
Posts: 4,073 Mo.
racerx
Mo.
At my work we have had nothing but problems with gear noise on every set of motive gears. I even called them and they wont guarantee there gears to be quiet. They told us to run 250 weight oil. What a joke. I wont even put a set in any more. We had no problems when we were using Yukon gears. But the motive's were cheaper so that's why we started using them, After many hours of playing with the pattern all to find out the noise wont go away. I had used motive many years ago and didn't have a problem but now there gears seem to be junk. And this isn't just 1 set, I have had this happen on at least 15 - 20 different diffs.
I'v never use a set of the Yukons just wondering what's your opinion on these gears?I see judging from there site they seems to be big in the 4x4 trucks how r they in race cars?.........not meaning to jack your thread.
[Re: RobR]
#1492307
08/30/13 11:56 PM
08/30/13 11:56 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
Doesn't look deep enough to me.. what the other side look like [coast side] ?
Here is the other side. Sorry Not a great pic.
[Re: Kam*Kuda]
#1492308
08/30/13 11:57 PM
08/30/13 11:57 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
and here is a better looks at the gear side finish
