Need accurate measurement on Strange Rear Coilovers #1492091
08/28/13 08:07 PM
08/28/13 08:07 PM
DERRY,NH
U
UNDERDOGG Offline OP
U
DERRY,NH
Can someone tell me where to measure on these Strange coil over shocks?
Part# on shock is 1408 but there is no number in their catalog with this #, so I'm trying to get an accurate measurement so I can cross reference these shocks to a set of double adjustable ones.
What does collapsed length without bumper mean? Thanks guys I'm a Newbie.
Re: Need accurate measurement on Strange Rear Coilovers [Re: UNDERDOGG] #1492092
08/28/13 08:47 PM
08/28/13 08:47 PM
ill
dennismopar73 Offline
ill
Collape the shock measure center of eye hole to eye hole , then pull the shock fully out measure it again center to center,, take the 2 measurments cut it in half that is the install hieght !
Re: Need accurate measurement on Strange Rear Coilovers [Re: dennismopar73] #1492093
08/28/13 09:05 PM
08/28/13 09:05 PM
DERRY,NH
U
U
DERRY,NH
Re: Need accurate measurement on Strange Rear Coilovers [Re: UNDERDOGG] #1492094
08/28/13 09:26 PM
08/28/13 09:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I assume you have a set of used shocks... but they
come with a rubber bumper at the top of the shaft to
cushion it from bottoming out... if its still there
just measure the bumper and subtract that from the
compressed length.. you might be best to call Strange
and see what they say about that number
Re: Need accurate measurement on Strange Rear Coilovers [Re: MR_P_BODY] #1492095
08/28/13 09:44 PM
08/28/13 09:44 PM
DERRY,NH
U
U
DERRY,NH
They are on the car and I really don't want to take them off.There is no rubber bumper on these coil overs.
Do you measure center of eyelit to center of eyelit? I'm so
Re: Need accurate measurement on Strange Rear Coilovers [Re: UNDERDOGG] #1492096
08/28/13 09:48 PM
08/28/13 09:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes... eyelet to eyelet... yours might be old enough
that they didnt have the bumper.... but you really
need to take one off to measure it right(without
the spring on it)
Re: Need accurate measurement on Strange Rear Coilovers [Re: MR_P_BODY] #1492097
08/28/13 10:13 PM
08/28/13 10:13 PM
DERRY,NH
U
U
DERRY,NH
Aren't the bodies all different sizes? Couldn't I get the collapsed measurement from bottom of eyelit to top of base of the shock? I'm just throwing this out there. This shock could be either the 2 tallest coil overs they make. Just not sure which one this is.
Re: Need accurate measurement on Strange Rear Coilovers [Re: UNDERDOGG] #1492098
08/28/13 10:17 PM
08/28/13 10:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would take one off... but its your car
Re: Need accurate measurement on Strange Rear Coilovers [Re: UNDERDOGG] #1492099
08/29/13 02:13 AM
08/29/13 02:13 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
The number on the shock is a serial number not a part number.
Just measure from the top mounting hole to the bottom one then look in their catalog for the closes ones to that.
