I have run plenty 318s with 360 intakes
yes its a little mis matched,cant really notice it from the seat dyno though
and I 2nd the Q-jet,that will get the throttle responce back some and feed it plenty o gas
the main thing with slapping a 4-v on a teen is the little cam dont like it but you will notice a gain in performance,same with swapping 360 heads on a stock teen...the cam cant feed the flow
swap the cam to some thing alittle bigger allways helps
I would suggest an LD4B intake and the square bore carb you have,its on par with a LD340 intake but for the 318 ports
and get over the thermo bog...quadra bog...holley gas hole thing....run what ya brung
send all q-Jets to me please
