Re: 340 vs 360 4bbl intake
[Re: 340SHORTY]
#149128
11/11/08 03:14 AM
11/11/08 03:14 AM
Posts: 5,163 CT
GTX MATT
CT
Yeah youre going to loose some throttle response with a 340 intake. Youre probably best off picking up an Edelbrock Performer 318/360, its designed for 318 ports, plus it will save some weight.
[Re: 69L78Nova]
#149130
11/11/08 12:26 PM
11/11/08 12:26 PM
The only people that call them that, are people with no brains that dont know how to work on them.
..or have had the plastic bodies warp on them rendering them useless and pissing gass all over a hot intake creating an inferno under the hood.
#149132
11/11/08 01:04 PM
11/11/08 01:04 PM
Posts: 683 CENTRAL MINN
1965_PLYMOUTH
CENTRAL MINN
I too, have seen too many leaking ones to be a lover of them. I do notice though that the small block ones do seem to hold up much better. the heat coming off the big block engine was too much for this carb.
[Re: 69L78Nova]
#149135
11/11/08 01:27 PM
11/11/08 01:27 PM
RapidRobert
Hi Scott. I would get a square bore 318 one for the ports to match. With the lack of cubes you wouldn't want to have any mismatch of parts that would hurt you if you can help it.
[Re: 69L78Nova]
#149136
11/11/08 01:41 PM
11/11/08 01:41 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Well these things were warping and cracking within a very short time of being new so it didn't take 30+ years of deteriorating to do the damage and warp and crack the bowls. There were more bad ones come in than good for repairs/replacement. If you were lucky and goe a good one they were great but-------------- PS: I am not a lover of Holley double pumpers on the street either. But over the last 40+ years have had a lot less problems with Holley carbs than Thermoquads. If you like them fine use them. If you find a good one.
[Re: RapidRobert]
#149137
11/11/08 02:35 PM
11/11/08 02:35 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
Thanks Robert. Is the mismatch what would cause the loss of throttle response with a 340 intake that GTX Matt spoke of? Could any of that be salvaged by grinding the ports to match the manifold?
[Re: RapidRobert]
#149139
11/11/08 03:09 PM
11/11/08 03:09 PM
I've run a 750cfm 3310 vacuum secondary Holley on a number of different cars/engines/setups that are driver type vehicles. The only time a power valve ever blew was when the car wasn't tuned right right after a rebuild. Oh yeah, at least I can get parts for said Holley when/if I need them.... ...but I usually don't. Where, again, can you find a new main body for a Thermobogger? While your fixin' I'll be
#149140
11/11/08 03:42 PM
11/11/08 03:42 PM
MoparforLife
Upper Midwest
[Re: 69L78Nova]
#149143
11/11/08 06:39 PM
11/11/08 06:39 PM
The factory 318 4 barrels used the 360 intake manifold. I wouldn't hesitate to use the factory iron manifold on a 318. The factory 340-360 manifolds were a great design, many aftermarket manifolds show a power loss in comparison.
Sheldon
