Re: Aluminum fuel cell with alcohol?
[Re: bobs69]
#1489653
08/24/13 10:01 AM
08/24/13 10:01 AM
Posts: 1,142 Central New York
slippery440
Crybaby440
Crybaby440
Central New York
I have been running E85 for 3 years with aluminum lines with no problem. I leave the fuel in all winter.
If the MODS did their job I would not be hitting the notify MOD button. LOL
[Re: slippery440]
#1489654
08/24/13 11:04 AM
08/24/13 11:04 AM
Challenger 1
Cincinnati, Ohio
Sorry but you will have problems sooner than later.
Methanol/ethanol will corrode the aluminum eventually. It's best to drain the cell after use. I ran aluminum fuel cells for 20 years and drained it after every weekend.
Plus storing alcohol fuel in a vented fuel cell allows water to get into your fuel and then corrosion will be 10X worse.
[Re: Challenger 1]
#1489657
08/24/13 05:28 PM
08/24/13 05:28 PM
slippery440
Crybaby440
Crybaby440
Central New York
I hear all the horror stories but not had a problem. Took the carb apart after sitting all winter(2 years) and found it clean. I changed the filter and I do use a micron filter and that was fine(2 years). I did use a stabilizer in the fall.No problem with the fuel pump witch is also aluminum.My car sits in a unheated pole barn all winter. I test the fuel and not found any differance from stored to new from pump.If e85 is going to effect aluminum we better switch back to iron heads and manifolds.
[Re: bobs69]
#1489658
08/24/13 06:16 PM
08/24/13 06:16 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Have you had any trouble running alcohol with an aluminum cell?
With a vent on the tank/cell the alky/E-85 WILL suck up moisture and moisture is what corrodes the alum.. if you keep the air away the alky/E-85 wont do anything
[Re: jcc]
#1489660
08/24/13 07:35 PM
08/24/13 07:35 PM
MR_P_BODY
Well yes and no, the moisture and alcohol combine to form an acid that corrodes the alum. Keeping them separate is the solution, but very difficult.
I think this best describes the reaction.
http://en.wikipedia.org/wiki/Deprotonation
I have 4 test samples still running(2 with E-85 and 2 with alky) 1 of each is air tight in alum the 2 others are in a vented alum... the air tight shows ZERO corrosion and the vented shows very little above the fuel level (this has been 4 years now).. thats with topping off both vented samples
[Re: MR_P_BODY]
#1489661
08/24/13 10:25 PM
08/24/13 10:25 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Well there is an explanation for everything, not sure I am sharp enough to explain your experiment's results so far. But since you have a technical background, how do you observe corrosion inside an airtight alum container?
[Re: jcc]
#1489662
08/24/13 10:38 PM
08/24/13 10:38 PM
MR_P_BODY
All 4 alum tanks I made with a real short filler neck and gas caps(production stuff) and 2 have vents.. I just open the cap and look in with a flash light.. then change the fuel and put the cap back on.. pretty simple... (to keep it air tight, fill it all the way up)
[Re: MR_P_BODY]
#1489663
08/26/13 01:28 PM
08/26/13 01:28 PM
Posts: 290 Norwalk Ohio
cudasteve68
Norwalk Ohio
I would anodize the tank. It is cheap to get done & you have a few choices of what colors you can get done. All of the race/street fuel fittings we make at work for customers are anodized for this reason. Mainly the import guys that run E-85
[Re: dizuster]
#1489665
08/26/13 03:11 PM
08/26/13 03:11 PM
dartman366
Mt. Vernon, Ohio
I know that the one time I left e85 in my carb for the winter it corroded like crazy in the bowls. Lots of guys don't have issues but I sure did.
I would say some of it is where you live and race too, race in a higher humidity area then your system would be more likely to capture moisture if it wasn't well sealed from the humid outside air, if you live in a dryer warmer climate you probably won't have near the issues,,I know guys that in the winter their garage floors would become wet if the temps during the day would rise up past the freezing point, I keep mine heated in the winter and have no issues with that, I believe that has a lot to do with individual result's.
[Re: dizuster]
#1489667
08/26/13 11:02 PM
08/26/13 11:02 PM
MR_P_BODY
The first year I ran E-85 I left it in the carb and had the same issue... because its vented.. since then I run gas through the system and run it dry then pour in some Stabilizer
[Re: Cab_Burge]
#1489670
08/27/13 09:37 PM
08/27/13 09:37 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
You think that just a little 10% or so shouldnt hurt! Think again, this is the second tank i'm having to replace. REC90 is all i'm going to use if I have my choice.
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#1489671
08/27/13 09:43 PM
08/27/13 09:43 PM
Copper Dart
the float almost completely disolved! you go ahead and take your chances with that BUNK science that ethanol is a good thing for the Earth. I will be making me some spending money replacing "others" classic cars tanks very soon. Heck, I just might become a Spectra Dealer.
