some time in the 90s the pump lugs changed to the flatson the TC snout.
those will not fit in a no-lock up or lock up trans that have the notched pump lugs in the TC snout.
the input shaft will either be a smooth end about 1" for the lock up.
the no lock up will have splines all the way to end of input shaft.
you will also need the correct weight on the TC for the 360engine.
if it is lock-up and you want non-lock up, you can block the LU valve and it will shift but not LU the TC.
I found that the pan rail #s can be very helpful but not always correct when checking them. I have found lots of rebuilt units that where changed/repaierd/moded in it liftime as they get older.
