Re: Exhaust flex section with headers?
[Re: davenc]
#1488792
08/22/13 11:47 AM
08/22/13 11:47 AM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
If your going to use flex pipe, make sure its stainless steel or it will not last and it will leak over time.
Snap your neck, mega G-force launch, is all I want!
[Re: davenc]
#1488795
08/22/13 01:41 PM
08/22/13 01:41 PM
Challenger 1
Cincinnati, Ohio
The standard header bolts are not long enough, especially for the TTI thicker flanges. I used longer bolts than the 7/8" long standard bolts. You can get longer header bolts than what is commonly available and that helps keep them tight. Mine have been in since 2007 when I replaced the motor and I have not touched them since. My collector gaskets are the same ones that TTI supplied and have been in service since 1999 when I installed them and they don't leak.
[Re: midnite360]
#1488799
08/22/13 06:11 PM
08/22/13 06:11 PM
Posts: 2,578 sweden
1Fast340
sweden
I had a set of Hedman Hedders that has the Gasketless flanges on them. Never had a problem with leaks. I wonder if somebody sells just the flanges and you can weld them in?
just go to the nearest mufflershop and ask them to make a pair of maleballs and a pair of femaleballs on the pipediameter of choice. this kind of connection known as balljoint is pretty much the standard connector between catalytic converter and exhaustpipe on gm products from the 70īs into the late 90īs if you already have a set of headers with this kind of connector you probably have standardized 3bolt headerflanges and the hedman hedders sometimes have a slightly odd balljoint shape in these instances just bring the header to the mufflershop and let them be alitle creative making the mating balljoint and you will have a nice sealing joint i prefer using 2bolt formed flanges (you dont want the flat ones,they are just cheap generic garbage compared to the formed ones imho)just like gm used to do,they are good 3" 2bolt flanges made for this kind of floating application is available from walker part# 31942 and this kind of flange is available in more sizes if needed
[Re: davenc]
#1488802
08/23/13 02:32 AM
08/23/13 02:32 AM
Posts: 5,789 Hamilton, Ontario Canada
Magnum
Our North/South mounted V8's should not flex. If anything they twist a bit. So make the connection as solid as possible and force the exhaust pipes to rock a bit with the engine.
The 3 bolt flanges that are welded are better than the loose rings. The flex joints are for west/east mounted engines. The lean back during acceleration and an exhaust pipe can't bend like that and survive.
[Re: Magnum]
#1488803
08/23/13 12:58 PM
08/23/13 12:58 PM
dogdays
Well. that's the old school version.
But it's inaccurate. Put a big load on a north-south engine car and the engine tries to twist the chassis like a rubber band. It's really noticeable in my truck when pulling a big load up a steep hill. If the exhaust system is mounted firmly to the engine and pretty firmly to the chassis, it stresses any joints in the system.
My feeling is that this is not a deal-breaker, because as I pointed out to the OP, when the exhaust pipes get hot, they become more flexible. But we are trying to make things better, in general. The guy who says, "good enough" soon starts losing every race.
The downside to flat header flanges using gaskets is that they are a typical failure point, plus the flanges tend to get in the way.
There has to be a reason that header manufacturers are using ball-and-socket ends on collectors. They cost more than a flat flange. But, eliminating the flat flange and gasket cuts out one failure point. Plus they can be a little more streamlined externally so less to drag, hit, etc.
R.
[Re: davenc]
#1488807
08/30/13 10:51 PM
08/30/13 10:51 PM
Magnum
Im all for better but even the newest car or truck with a north south engine has no flex joint.
Only seen them on west east set ups. Which is necessary when an engine leans back during torque.
