Oil for my 76 Dodge 1 Ton #1487102
08/19/13 10:16 PM
08/19/13 10:16 PM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
i have a 1 ton i pull my camper with, big block with stock cam and valve springs.
does Shell Rotella , still have any zinc in it?
what would work beings this is not High Performance vehicle, doesn't need the High Performance oil.
Re: Oil for my 76 Dodge 1 Ton [Re: 4spdana] #1487103
08/19/13 10:18 PM
08/19/13 10:18 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I'd use the 15w40 Rotella. Good oil and enough zinc in it.
Nautilus Racing-
Re: Oil for my 76 Dodge 1 Ton [Re: 4spdana] #1487104
08/19/13 10:19 PM
08/19/13 10:19 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Unfortunatly the Hi Po oils are about the only 1 that have Zink in them.. Diesel oil is 1 of the others but even those have less Zinz than they used to... Zink additives are reccomended..
I am truckless..
