possible state of emergency
#1486442
08/18/13 08:49 PM
08/18/13 08:49 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I broke a Manley 13093 valve lock. Summit and Jegs have ship dates of 8/26 on this item. I plan on calling Manley tomorrow but not sure if they will be much help I found my lower ball joints (actually upper ball joints) moving up and down a half inch and replaced them with MOOG today. have yet to get the little grease fitting to screw in after a half hour of trying. pulled the headers out to goop them up with red permatex in hopes they seal exhaust leaks. didn't know I didn't need to pull the oil pump to change cams, which turned into dropping the pan for the 3rd time in 3 weeks. I'm stupid I have showered and changed clothes 3 times, I'm a puddle of mud right now. if anyone happens to have the valve locks I need, would you be willing to ship them to me and I'll buy you new ones(depending on what Manley tells me tomorrow) the clock is ticking, and I'm getting nervous. Person I worked with for past 8 years quit and I'm trying to do the job of 2 people at work also.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: possible state of emergency
[Re: pittsburghracer]
#1486444
08/18/13 09:29 PM
08/18/13 09:29 PM
sixpackgut
Charleston
no, mine are a single bead at the very top of the lock. its a bit different than the norm
[Re: sixpackgut]
#1486445
08/18/13 09:37 PM
08/18/13 09:37 PM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Picture may help so we can try to round you up some.
[Re: ksj]
#1486450
08/19/13 10:31 AM
08/19/13 10:31 AM
sixpackgut
Charleston
[Re: sixpackgut]
#1486451
08/19/13 10:39 AM
08/19/13 10:39 AM
Posts: 181 Charleston SC
67383s
Charleston SC
Glad you found them, Keep your head up, and call if you need an extra set of hands.
Steve Bright Charleston SC
[Re: 67383s]
#1486452
08/19/13 11:44 AM
08/19/13 11:44 AM
sixpackgut
Charleston
If you could just hose me down with cold water while I'm working that would be great, but there is no cold water in south Carolina in august
[Re: sixpackgut]
#1486453
08/19/13 12:47 PM
08/19/13 12:47 PM
Quicktree
don't you have a/c in the garage?
[Re: Quicktree]
#1486454
08/19/13 01:09 PM
08/19/13 01:09 PM
sixpackgut
Charleston
I did, don't know if it still works because I swore I would never turn it on again. it ate money
[Re: sixpackgut]
#1486455
08/19/13 01:15 PM
08/19/13 01:15 PM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
But that is the advantage living where you don't have to HEAT your house in the winter...We get to burn all of our $$$ in the winter here at 10°! Not to mention what snow removal equipment costs...
Good luck, and I am routing for you. Kicked A$$ last year, and really made a lot of us very happy to see you win..Wish they would have covered your car more in the vids...
[Re: Dragula]
#1486456
08/19/13 01:57 PM
08/19/13 01:57 PM
sixpackgut
Charleston
thanks, I would run 3 times and leave before they even had their cameras setup most days.
and I'm from PA, I know all about paying for heat
[Re: sixpackgut]
#1486457
08/19/13 02:45 PM
08/19/13 02:45 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
Glad you found them Ray. I have about 175 miles on mine now and I hope to hit the track Friday night.
68 Barracuda Formula S 340
[Re: sixpackgut]
#1486460
08/19/13 04:52 PM
08/19/13 04:52 PM
Dragula
Is that a little anemic Eddy carb on that engine? Most guys are running some pretty good size carb on them. How did you do the ignition set-up?
I just love when people hate on my carbs. for years everyone told me to take the six pack off, now its take the edelbrock off.
I have the MSD hemi 6 on it
Not hating on it, but my understanding is the G3's prefer more carb than most conventional thinking would call for. What size is it? And I am pretty sure you ran a pair of them on your previous wedge combo...They take a little tinkering just like any carb. I am not famialiar with their Thunder series carbs either, just the old style ones.
On the ignition is it user programable? use setup the entire curve?
[Re: Dragula]
#1486461
08/19/13 07:49 PM
08/19/13 07:49 PM
sixpackgut
Charleston
it has a timing curve that you can change. retard. rev limiter. map curve. works good
