Which BB water pump?
#148641
11/10/08 09:37 PM
11/10/08 09:37 PM
Posts: 12,293 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
What with all the water pumps available now, I thought I would check and see what pump everyone thinks is the best bang for the buck. Quite frankly, I have always used a pump from one of the big chain stores with no problems. The one on my street/strip 499 now is just starting to weep a little, so it's time to be replaced. Are the big dollar pumps worth the extra bucks? Or will the AutoZone/O'Reilly's/Advanced kind do as good a job at cooling the big block. Additional details; Al. heads, iron block, 6,200 rpm limit, good orig. type radiator, stock pulleys Thanks!
Master, again and still
Re: Which BB water pump?
[Re: ahy]
#148643
11/10/08 11:39 PM
11/10/08 11:39 PM
RapidRobert
pop rivet an anticavitation plate on the vanes while you're at it.
[Re: 62maxwgn]
#148645
11/11/08 09:54 AM
11/11/08 09:54 AM
thats what i have on mine... ![](/ubbthreads/images/graemlins/punkrocka.gif)
[Re: John_Kunkel]
#148647
11/11/08 04:28 PM
11/11/08 04:28 PM
RapidRobert
& for the last word go here. www.moparchat.com then scroll down to & click on "circle track chat" then peruse Sanborns cooling(& oiling) mods that are in a sticky at the top of the page(for good reason).
[Re: John_Kunkel]
#148648
11/11/08 04:43 PM
11/11/08 04:43 PM
RapidRobert
[quote A/C pumps are normally driven 140% of crankshaft speed.
they're not overdriven that much are they John? I was thinking it was 114% or somewhere close to that.
[Re: RapidRobert]
#148649
11/11/08 07:43 PM
11/11/08 07:43 PM
Posts: 25,992 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Check the FSM, a drive ratio of 1.4 is common for A/C equipped BB's.
