97 Cummins upgrades
#1485817
08/17/13 03:33 PM
08/17/13 03:33 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
So I have a customer who wants "100 more HP". I don't think he really knows what that means but he wants to get an upgraded turbo, injectors, fuel plate, cold air intake, and really quiet/more power exhaust. What are decent upgrades to recommend him without breaking the bank?
Re: 97 Cummins upgrades
[Re: HotRodDave]
#1485818
08/17/13 03:58 PM
08/17/13 03:58 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
A #10 BD fuel plate, 4 or 5" exhaust and the cold air kit will probably give him 70 or so more HP and 150 lbs more torque. Just make sure it's a BD plate...not some generic copy....those aren't very good. You could also put some upgraded governor springs in the pump which will give him an honest 400 RPM more pulling range. Nice for towing.
[Re: cascius]
#1485822
08/17/13 11:07 PM
08/17/13 11:07 PM
HotRodDave
Kalispell Mt.
I already built his trans in anticipation of this with extra clutches, cooling and a shift kit. I have a billet low stall converter (300 rpm under stock with a stock engine)brand new on the shelf with his name on it. The truck has a Dana 80. When we did his head gasket we put in some $800 head studs. He still has the cat in it and he can ditch that if he wants.
He seems bent on upgradeing the turbo and he says the 24v turbo is better, is that a good idea?
[Re: superwrench]
#1485824
08/18/13 01:08 AM
08/18/13 01:08 AM
Posts: 4,086 The Wet Coast, Canada
megajoltman
First....GAUGES 3K or 4K gov spring kit (HD valve spring upgrade) + AFC tune + fuel plate mod + timing + 4inch exhaust.
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
