mig welder lincoln mig 15 is it good #148576
11/10/08 08:16 PM
11/10/08 08:16 PM
quebec,Canada
swinger72 Offline OP
quebec,Canada
i have the luck to get my hands on a lincoln mig 15 220 v i plan to use it for body panels can anyone tell me if they are good for that use, i am not a welder so i will have to practice ,also is it better to weld with argon or just the wire ? thanks Mike
Re: mig welder lincoln mig 15 is it good [Re: swinger72] #148577
11/10/08 10:39 PM
11/10/08 10:39 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Its a good one. Use the gas for cleaner welds. http://www.toolfetch.com/Category/Weldin...n=Trafficleader
Re: mig welder lincoln mig 15 is it good [Re: earlybee] #148578
11/10/08 10:51 PM
11/10/08 10:51 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
cleaner welds plus cheaper to run I think depending on local prices and availability. YMMV
Re: mig welder lincoln mig 15 is it good [Re: earlybee] #148579
11/10/08 10:55 PM
11/10/08 10:55 PM
OHIO
1970EBODYS Offline
1970EBODYS  Offline
OHIO
lincoln makes great welder i would use argon and co2 mixture 80%20% or 75%25% depends on where you get your gas use 0.23 wire and low heat tack welding
and moving around when welding sheet metal and 0.35 wire for thicker metal
1970 Cuda 440-6 Shaker clone project 1970 Challenger 383 project
Re: mig welder lincoln mig 15 is it good [Re: 1970EBODYS] #148580
11/10/08 11:28 PM
11/10/08 11:28 PM
NH
Fastback67 Offline
Fastback67  Offline
NH
Always use a gas shielded wire when working on body panels etc.
Flux-Core has it's uses too... It's much better at general purpose welding on things like old angle iron and flat bar etc, especially dirty old rusted stuff, because it has the ability to clean the weld from within. It is however much to violent for thin sheet metal work like body panels. Plus there is a lot of weld splatter that goes along with using Flux-Core on anything.
Re: mig welder lincoln mig 15 is it good [Re: Fastback67] #148581
11/11/08 11:13 PM
11/11/08 11:13 PM
quebec,Canada
quebec,Canada
thank you for your replys , i picked the welder up this evening , so now its just a matter of learning to weld lol
