Page 2 of 3 1 2 3
Re: 230 - 260 leaf springs and 1.26" torsion bars [Re: Mopar Mitch] #1485540
09/08/13 07:03 AM
09/08/13 07:03 AM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
One additional concern should be, if the front spring eye location is changed up/down then to use angle shims at the leaf/differential to re-adjust the drive shaft / pinion angle.
Good point! What pinion angle would you dial in on a roadracing HEMI car ?
We used -4° in drag racing, but that might be a lot for the road circuit
Re: 230 - 260 leaf springs and 1.26" torsion bars [Re: docford] #1485541
09/09/13 10:56 AM
09/09/13 10:56 AM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Docford -- I'm uncertain what to advise for the pinion angle for the car you describe. I believe the Mopar Performance Chassis book, etc, advise how to do this.... you'll probably need an angle gage. (I had a racer-pro (Jim McKamey) do mine as I was also having the entire suspension balanced... back in the mid-80s.)
Re: 230 - 260 leaf springs and 1.26" torsion bars [Re: Mopar Mitch] #1485542
11/24/13 07:03 PM
11/24/13 07:03 PM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
Torsion bars and leaf spring came in this week. They were custom made by FirmFeel
Re: 230 - 260 leaf springs and 1.26" torsion bars [Re: docford] #1485543
11/24/13 08:58 PM
11/24/13 08:58 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Re: 230 - 260 leaf springs and 1.26" torsion bars [Re: docford] #1485544
11/25/13 03:36 PM
11/25/13 03:36 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Post up some pictures please!
Re: 230 - 260 leaf springs and 1.26" torsion bars [Re: docford] #1485545
11/25/13 06:59 PM
11/25/13 06:59 PM
Mopar Mitch Offline
Mopar Mitch  Offline
What were the final specs on the TBs and leafs? This is for a hemi-Cuda? Which body.. E or A? Which gen-Hemi?
Re: 230 - 260 leaf springs and 1.26" torsion bars [Re: Mopar Mitch] #1485546
12/22/13 07:52 AM
12/22/13 07:52 AM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
1.24" torsion bars
1.25" frt sway bar
230# leaf springs
0.75 rear sway bar
1970 Cuda with 426 HEMI
3780# w driver and half tank of gas
weight bias 54% frt 46% rear
complet car can be seen here http://www.hemicuda-france.com
Re: 230 - 260 leaf springs and 1.26" torsion bars [Re: docford] #1485547
12/22/13 08:17 AM
12/22/13 08:17 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
1.24" torsion bars
1.25" frt sway bar
230# leaf springs
0.75 rear sway bar
I assume those T-bars were made on the factory A/B/E-body 1.25" front and rear hex?
Are those T-bars factory E/B body length?
I think comparing to a late 60's to mid 70's Nascar cup car chassis it out the window. Those T-bars are a different length AND the lower control arms are a different length too. So the calcs to get the wheel rates are a different animal than your stock E/B body LCA and T-bar length. I also would not assume the '70 Trans Am cars uses stock length T-bars and LCA's. Not saying they didn't, but I would want a measurement confirmation.
IMHO, a 230 lbs rear spring on a road course seem like a lot for 1.24" dia E/B-body length torsion bars. But, what was Dick Ross's recomendation/advice?
It looks like you have been racing this same car for the past 3 years? What springs were in it then?
Was there a problem with that spring package?
Re: 230 - 260 leaf springs and 1.26" torsion bars [Re: autoxcuda] #1485548
12/23/13 03:42 AM
12/23/13 03:42 AM
Mopar Mitch Offline
Mopar Mitch  Offline
On my T/A, I run the 1.24 TBs and 225 pound/inch with 5" free arch rear leafs (fiberglass mono-leafs from FlexaForm)... compressed to about 1.5" remaining arch,... and have 1.25" solid fron sway bar, 1.0" solid rear sway bar, Red re-valved Konis front/rear... car handles great, very neutral; weight is ~3150 w/o driver and with ~1/8 tank of gas (52% front, 48% rear)... this data is when the car is setup for national SCCA E/SP competition. even on the hi-speed road courses it handles great.. still relatively neutral.
I think the weight% with the 426 Hemi up front is going to be greater than what is indicated...??? I'd use a 1.0" rear sway bar to help offset the front weight.
Re: 230 - 260 leaf springs and 1.26" torsion bars [Re: Mopar Mitch] #1485549
12/23/13 12:43 PM
12/23/13 12:43 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
The more you move weight rearward, the higher your rear rates need to go to balance things out. With a 54% front bias WITH an elephant up front, more leaf rate is probably required. I would have guess a Hemi equipped car to be more like 58-60% front weight, so the change to 54% is a significant change.
Re: 230 - 260 leaf springs and 1.26" torsion bars [Re: TC@HP2] #1485550
12/23/13 05:52 PM
12/23/13 05:52 PM
Mopar Mitch Offline
Mopar Mitch  Offline
Best bet would be removing weight from the car.. that 426 hemi is very heavy. It'd be interesting to see the actual weigh scale results, each respective corner.
Re: 230 - 260 leaf springs and 1.26" torsion bars [Re: Mopar Mitch] #1485551
02/02/14 07:11 PM
02/02/14 07:11 PM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
Weight with half a tank of gas and driver is 3,780 lbs
Front/Rear bias is 54/46
Left/Right bias is 52/48
We are now moving the fuel and dry sump tank to get 50/50 left to right weight bias. We are also removing about 40 lbs by doing that, thanks to shorter routing of the -16 oil hoses and thus, carrying less oil in the dry sump circuit
Re: 230 - 260 leaf springs and 1.26" torsion bars [Re: docford] #1485552
08/17/14 06:05 AM
08/17/14 06:05 AM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
The new springs worked wonders on the Nurburgring, as we were able tonshave a full 26 seconds of our best lap time from 2012. Lapping the 14 mile roadcourse in 8.52 made us a Porsche Terror !!
Here is the onboard video
http://www.hemicuda-france.com/2014/08/onboard-the-hemicuda-around-the-nordschleife.html
Re: 230 - 260 leaf springs and 1.26" torsion bars [Re: docford] #1485553
08/17/14 10:35 AM
08/17/14 10:35 AM
Irving, TX
feets Online tonguue
Senior Management
feets  Online Tonguue
Senior Management
Irving, TX
Very nice!
It begs the question of what time could it turn on a dry track with more cooperative traffic?
- Stu Harmon
Re: 230 - 260 leaf springs and 1.26" torsion bars [Re: docford] #1485554
08/17/14 02:00 PM
08/17/14 02:00 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
That car is awesome! Man you got big balls running hard in the rain! Nice save too! Last time I was in the wet my car spun and had a fender bender.
Your car moves pretty good despite the weight. The leafs and t-bars must be heavy but really make a difference!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: 230 - 260 leaf springs and 1.26" torsion bars [Re: RylisPro] #1485555
08/17/14 03:02 PM
08/17/14 03:02 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I've really been kicking around the splined front swaybar idea. Basing it from my existing Hotchkis mounts, it really would'nt be to much of a stretch.
Mopar to the bone!!!
Re: 230 - 260 leaf springs and 1.26" torsion bars [Re: 72Swinger] #1485556
08/17/14 07:22 PM
08/17/14 07:22 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I assume what I am asking about is just a video or mounting visual distortion artifact, but does it look like the trans tunnel area/rear TB mounting crossmember flops around a lot based on bumps and/or cornering? Nothing else inside the car seems to move much, relative to camera, but this area. If so wow, if not nevermind.
Re: 230 - 260 leaf springs and 1.26" torsion bars [Re: docford] #1485557
08/18/14 02:47 AM
08/18/14 02:47 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
that was a really cool video
Re: 230 - 260 leaf springs and 1.26" torsion bars [Re: RylisPro] #1485558
08/18/14 04:57 AM
08/18/14 04:57 AM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
Thanks yes , the Cuda now is really fun to drive and one could even let his mom cruise it on the street
Re: 230 - 260 leaf springs and 1.26" torsion bars [Re: jcc] #1485559
08/18/14 04:59 AM
08/18/14 04:59 AM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
Interesting observation! I'll take a second look at the video
Page 2 of 3 1 2 3
