1978 dodge aspen super coupe #148527
11/10/08 06:39 PM
11/10/08 06:39 PM
ohio
70alpinewhiteta Offline OP
ohio
found a 1978 dodge aspen super coupe that has the A67 code on the fender tag, but came with an E55 360 2 barrel engine and D36 904 torqueflite trans. i thought all A67 super coupes came with E58 360 4 barrel engines. does any one know more about these cars?
Re: 1978 dodge aspen super coupe [Re: 70alpinewhiteta] #148528
11/10/08 08:34 PM
11/10/08 08:34 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Check the serial number on the dashplate (near the defroster opening), if you find a "K" about the 5th space, that'll clear it up.
A 360-2 is "K", a 360-4 HP is "L". At least on the late B's, I'm sure the engine codes are the same across the model line.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: 1978 dodge aspen super coupe [Re: Magnumguy] #148529
11/11/08 09:11 PM
11/11/08 09:11 PM
Kitchener, Ontario, Canada
moparrlz Offline
super street
moparrlz  Offline
super street
magnumguy you are correct the F-bodies were the same as you mentioned.
If it is a real super coupe it should have the L in the Vin.
Fred
Re: 1978 dodge aspen super coupe [Re: moparrlz] #148530
11/11/08 11:15 PM
11/11/08 11:15 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
And.... along with the "L", on the fender (VIN)tag, it should have, I believe, an A67, 2nd or 3rd row up from the bottom.
