Re: Question on 6 Pack Vaccuum requirement
[Re: Twostick]
#1484982
08/15/13 02:29 PM
08/15/13 02:29 PM
Posts: 3,916 usa
lewtot184
usa
Manifold vacuum has nothing to do with opening the outboard carbs.
Kevin
x2, it's air velocity thru the passenger side center carb venturi. look for a fuel delivery problem.
[Re: superwrench]
#1484985
08/16/13 01:58 AM
08/16/13 01:58 AM
Posts: 233 vashon island washington
hunterstroble
I had a new engine I wass dissapointed with until one day I noticed my throttle cable was only opening up the throttle 75%. Dumb question, is your throttle getting max pull?
1969 Dodge dart 500 stroker
1973 Dodge Challenger 440
[Re: superwrench]
#1484987
08/16/13 10:22 AM
08/16/13 10:22 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Make sure those end carbs cycle freely... and another thing that might sound stupid......make sure the base gasket is on the right way otherwise the end carbs will NOT open. I've ran into that twice on a couple of customers cars. As said, engine vacuum has nothing to do with the end carbs opening.
x2 - the gaskets can also hold the secondaries open... DAMHIK
[Re: superwrench]
#1484988
08/16/13 10:58 AM
08/16/13 10:58 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
why do you have the idle so low? I'd think you'd want it a tad higher. I'm running a solid roller, (588) I pull about 8-9 at idle (900-1000rpm) I'm running the stock MP 6-pack, I'm using 70main jets (probably a tad rich) 35 squirters, and purple springs. I'd probably go back to square one, set your timing in full at 36* early 2200rpm, turn you mixture screws all the way in them out a turn and go from there, tweak for best vacuum. You should also make sure your outboards are opening 100% Your build should fly. not sure how the billet blocks work, but it should run fine w/ or w/o them. I adjusted my primary w/o the outboards hooked up. Good luck
[Re: lewtot184]
#1484993
08/16/13 04:02 PM
08/16/13 04:02 PM
Posts: 476 Mount Airy, Maryland
scrag
Well I took a the vacuum lines off and tested each carb - rear carb works like a champ front carb hisses....diaphragm is toast and it is my fault as I over tightened the cover when I was swapped the springs out....and of course no one in MD has a 135-6 diaphragm. I have one place left to try...thanks for the help. I am also going to spring is lt silver and not yellow btw...
[Re: scrag]
#1484996
08/16/13 06:20 PM
08/16/13 06:20 PM
Mr.Yuck
Brookeville, Md
I have one or 2 on my bench... except I'm in SC until Sunday. If you can't find one by then PM me. Advanced Auto has a complete re-build kit however it's like $35
[Re: 62maxwgn]
#1484998
08/16/13 09:15 PM
08/16/13 09:15 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
Have a few !! Also,put a little grease on the screws,if not the screw can catch and tear the rubber around the hole if the opening is not centered over the hole.o
Like he says....
[Re: scrag]
#1485002
08/18/13 09:39 PM
08/18/13 09:39 PM
Posts: 4,314 Prospect, PA
BSB67
Prospect, PA
... I was told smooth is the word when it comes to secondary operation....
You were told wrong. If you are trying to maximize performance, you can only determine the best spring at the track. The springs that generate the lowest et, best mph, may, or may not be smooth on the street. Weight, gear, and converter play a key role in what springs are best, and whether or not there will be a sag when they come-in on the street.
[Re: BSB67]
#1485003
08/18/13 10:25 PM
08/18/13 10:25 PM
Posts: 3,916 usa
lewtot184
usa
what BSB67 says is fact. as far as the short yellows slowing a car down; the short yellows actually have a slower opening rate than the long yellows. this is per holley's info. i don't know why they even marketed them. i use purples for street use but yellows go quicker. from a standing start you won't feel any soggy spots, like from a kickdown, with softer springs. anything heavier than purples is worthless.
