Re: 383 to 440 [Re: CYACOP] #148497
11/11/08 04:38 PM
11/11/08 04:38 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Im thinking on getting a core engine and rebuilding it over time for my 71 RR. Currently has a 383 but may go to 440 depending on what extras I would need to get. My 383 currently has AC. If I go with a 440 what off my 383 wont fit other than the intake manifold? Will my exhaust manifold height be the same? Actually 440's seem to be more readily available than 383's in this area as cores. Suggestions?
With all the stroker kits around today, why make
work? You have a 383 in there right now, and
everything works and fits right. From what I
see, you can stroke a 383 up to 496 cubes.
Then all your brackets and pumps and pullys
all still fit. And A/C is awesome on a 71 RR.
Throw a stroker kit from 440 Source, or Muscle
Motors, or even Hughes, in it and have a killer
street car that looks stock and tell everyone
it's just a little 383.
Snap your neck, mega G-force launch, is all I want!
Re: 383 to 440 [Re: BDS871Cuda] #148498
11/11/08 05:15 PM
11/11/08 05:15 PM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
Wow! Thanks for the replies. There sure seems to be a wide mix of suggestions. I think I will just go with what comes next but I think for a street car I would be better off going with a 383 or 400 as a base and build from there.
Re: 383 to 440 [Re: CYACOP] #148499
11/11/08 09:08 PM
11/11/08 09:08 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
I was in same situation as you. I needed to rebuild the original 383 in my RR and intended to build it up a little but keep it stock appearing.
Long story short I found a deal on a 440 and spent exactly the same as if I had rebuilt my 383.
I cleaned up the old 383 accessories (air cleaner, manifolds, etc) and put them on the 440. Even kept a 383 pie tin on it to fool the brand x guys.
I don't regret it for a second! Runs way better than the 383 and looks more original than the 383 when I bought it!
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: 383 to 440 [Re: wingman] #148500
11/11/08 10:25 PM
11/11/08 10:25 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Most people cant tell an RB from a B anyway, even a Mopar eye has to look twice to be sure. A stroker kit from 440source is what, 1800 bucks? And you really should have the rods checked anyway, you can buy a 440 rebuild kit for like 600 and if your rods check out alright, you dont have to spend anything extra on machining. The 440 winds up cheaper than a stroker. Although a 451 will rev up quicker. I still say unless youre going for all out as much HP as you can get go with a 440. With stock rods parts wont be too much and 450 horse is easy.
