Re: Paint guys...DP60, and then?
[Re: Sixpak]
#148453
11/10/08 04:38 PM
11/10/08 04:38 PM
Posts: 20,731 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
You will need to scuff/sand the dp and then topcoat it with dp again followed by your surfacing primer. You only have a week to cover the dp with something else or you have to start over.
PPG single stage is called DCC??? If you want a factory mopar color you need to see if it's available. The color choices ppg offers on the 60's colors is slim. The local supplier here can mix the popular high impact colors and that is about it. Anything pre 69 and your are out of luck unless you have a nice original paint sample that can be put under the prophet scanning tool.
[Re: Sixpak]
#148455
11/10/08 05:18 PM
11/10/08 05:18 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Use only a 2k product like autobody icing. Its pretty much thinned bondo. Works great.
Concept DCC is a single stage urathane. Make sure you cut and buff quickly because once it really cures its tough stuff.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
